RaceCapture App User's Guide
About the guide
Navigation
Home View
  • Analysis
  • Dashboard
  • Setup
Navigate through the app
Compatible OS
How to Install
On Desktop
On Raspberry Pi
Icons Used in Manual
Icon Description
Important information
Good to Know
Mandatory action
Help
Setup Wizard
Upon running the RaceCapture app for the first time, you are presented with a first time setup wizard. Follow the steps given below to configure your device..Mandatory Action.jpg
Welcome Page:
  • Click 'Next' on the welcome page to proceed to the device setup.
Device Selection:
  • Choose your RaceCapture device from the provided list.
  • Click 'Next' to move to the connection page.
Connection Setup:
  • Connect your system to the USB port.
  • Wait for the connection to establish; your device will be recognized once connected.
NoteGood to Know.png: You can access first time setup again by navigating to the main Setup page and selecting First time setup (as shown in the instruction below)
Navigating Dashboard Pages
Importing a new dashboard
  • Click on the gear icon located at the top right corner, and select the rectangular 'Add' icon.
  • In the 'Add' icon, you'll find three options:
    • System
    • Your
    • Shared
  • Choose your preferred option and scroll down to explore the available dashboard templates.
  • Press 'Select' next to the desired dashboard template to import it.
Racecapture customize gauge.gif RaceCapture app provides, plenty of options for customizing gauges, and designing your own attractive gauges.
To edit a gauge:
  • Unlock the dashboard
    • Display channel
    • Color
    • Min/Max range
Analog Gauges
For customizing Analog gauges, follow the instructions given below Customizing Analog Gauges (3).gif
  • Press the gear button on the gauge and select the edit option
  • From the top bar, select the Channel and change the channel as per your requirement.
  • After selecting channel, select the setting option at the top bar and select Analog Gauge editor.
  • In Analog Gauge editor, there are tons of customizable options, with a handy preview area.
Note : For more information, Click here
Digital Gauges
Customizing Digital Gauges.gif For customizing Digital gauges, follow the instructions given below
  • After selecting channel, select the setting option at the top bar and select Digital Gauge editor.
  • In Digital Gauge editor, there numerous customizable options available
Dashboard Alerts
Use the central alerts editor: Dashboard Alert .gif
  • Access the dashboard settings by clicking on the gear icon.
  • In the Alert rule tab, users can configure the alert active range, alert active after time, alert deactivate after time, and can also select the notification methods (Popup "Alert" or "Set Gauge color").
Customize Notification
  • Popup Alert notification: users can customize the message and color of alert by clicking on " add new action> selecting Popup: "Alert" > and change the message and color as per their need.
  • In Set Gauge color: users can customize the color of gauge by clicking on " add new action> selecting Set Gauge Color > Color
Edit alerts from gauges:
  • Edit a gauge
Customizing your dashboard
  1. Unlock the dashboard page by unlocking the gear icon present at the top right corner
  2. After unlocking the gauge icon, open the gauge icon by clicking the gear icon.
  3. In the add gauge option, select the gauge type, channel type, and configure the gauge setting as per your requirements.
Saving your dashboard
  • Click the gear icon at the top right corner to unlock the dashboard.
  • Click the save icon.
  • Under the "Create New" tab, press "New."
  • Provide a name for your dashboard and save it.
Predictive Lap timing
Analysis
  • Note: The system default is to trigger on Speed
Navigating data
Cursor across line chart
Playback Control
  • Zooming For line charts, you can zoom on the data using a two-finger pinch gesture, or using the mouse scroll wheel or your laptop's trackpad scroll gesture.
Selecting time vs distance
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Steps to recover:
  • Connect RaceCapture via USB
Extra Information
