RaceCapture App User's Guide
About the guide
Home View
- Analysis
- Dashboard
- Setup
Compatible OS
How to Install
On Desktop
On Raspberry Pi
Icons Used in Manual
Icon | Description |
Important information | |
Good to Know | |
Mandatory action |
Help
Setup Wizard
Upon running the RaceCapture app for the first time, you are presented with a first time setup wizard. Follow the steps given below to configure your device..
Welcome Page:
- Click 'Next' on the welcome page to proceed to the device setup.
Device Selection:
- Choose your RaceCapture device from the provided list.
- Click 'Next' to move to the connection page.
Connection Setup:
- Connect your system to the USB port.
- Wait for the connection to establish; your device will be recognized once connected.
Note: You can access first time setup again by navigating to the main Setup page and selecting First time setup (as shown in the instruction below)
Importing a new dashboard
- Click on the gear icon located at the top right corner, and select the rectangular 'Add' icon.
- In the 'Add' icon, you'll find three options:
- System
- Your
- Shared
- Choose your preferred option and scroll down to explore the available dashboard templates.
- Press 'Select' next to the desired dashboard template to import it.
To edit a gauge:
- Unlock the dashboard
- Display channel
- Color
- Min/Max range
Analog Gauges
- Press the gear button on the gauge and select the edit option
- From the top bar, select the Channel and change the channel as per your requirement.
- After selecting channel, select the setting option at the top bar and select Analog Gauge editor.
- In Analog Gauge editor, there are tons of customizable options, with a handy preview area.
Note : For more information, Click here
Digital Gauges
For customizing Digital gauges, follow the instructions given below
- After selecting channel, select the setting option at the top bar and select Digital Gauge editor.
- In Digital Gauge editor, there numerous customizable options available
Dashboard Alerts
- Use the central alerts editor
- Edit alerts from gauges
- Access the dashboard settings by clicking on the gear icon.
- In the Alert rule tab, users can configure the alert active range, alert active after time, alert deactivate after time, and can also select the notification methods (Popup "Alert" or "Set Gauge color").
Customize Notification
- Popup Alert notification: users can customize the message and color of alert by clicking on " add new action> selecting Popup: "Alert" > and change the message and color as per their need.
- In Set Gauge color: users can customize the color of gauge by clicking on " add new action> selecting Set Gauge Color > Color
- Edit a gauge
Customizing your dashboard
- Unlock the dashboard page by unlocking the gear icon present at the top right corner
- After unlocking the gauge icon, open the gauge icon by clicking the gear icon.
- In the add gauge option, select the gauge type, channel type, and configure the gauge setting as per your requirements.
Note : For create a data-driven color-changing dashboard background Check Here
Saving your dashboard
- Click the gear icon at the top right corner to unlock the dashboard.
- Click the save icon.
- Under the "Create New" tab, press "New."
- Provide a name for your dashboard and save it.
Predictive Lap timing
Analysis
Loading a Session:
Users can load sessions by:
- Pressing the (+) button at the bottom of the pop-out list of laps.
- Alternatively, press the gear icon on the dashboard and select 'Sessions'.
- On the home screen, click on the 'Analysis' option.
- Press the (+) button at the bottom of the pop-out list of laps.
- A new tab will open; in this new tab, select the 'Import Log' option.
- Under 'Import Log,' press the 'Select' option under Datalog file and import the log file.
Note: Users can also import datalog video files by clicking the 'Select' option under Datalog Video file.
Cursor across line chart
Playback Control
Zooming
If the data contains lap times, the laps will be shown in the dropdown list on the right. Select the laps you wish to compare; users can compare up to 4 laps at once from the same session or different sessions.
Performance Metrics
Data Visualization
Customizing Views
Comparative Analysis
Selecting time vs distance
Comparing laps / runs between sessions(Comparative Analysis)
Advanced Analysis Tools
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Steps to recover:
- Connect RaceCapture via USB
Extra Information
