RaceCapture App User's Guide
About the guide
Navigation
Home View
  • Analysis
  • Dashboard
  • Setup
Navigate through the app
Compatible OS
How to Install
On Desktop
On Raspberry Pi
Icons Used in Manual
Icon Description
Important information
Good to Know
Mandatory action
Help
Setup Wizard
Upon running the RaceCapture app for the first time, you are presented with a first time setup wizard. Follow the steps given below to configure your device..Mandatory Action.jpg
Welcome Page:
  • Click 'Next' on the welcome page to proceed to the device setup.
Device Selection:
  • Choose your RaceCapture device from the provided list.
  • Click 'Next' to move to the connection page.
Connection Setup:
  • Connect your system to the USB port.
  • Wait for the connection to establish; your device will be recognized once connected.
NoteGood to Know.png: You can access first time setup again by navigating to the main Setup page and selecting First time setup (as shown in the instruction below)
Navigating Dashboard Pages
Importing a new dashboard
  • Click on the gear icon located at the top right corner, and select the rectangular 'Add' icon.
  • In the 'Add' icon, you'll find three options:
    • System
    • Your
    • Shared
  • Choose your preferred option and scroll down to explore the available dashboard templates.
  • Press 'Select' next to the desired dashboard template to import it.
To edit a gauge:
  • Unlock the dashboard
    • Display channel
    • Color
    • Min/Max range
Analog Gauges
  • Press the gear button on the gauge and select the edit option
  • From the top bar, select the Channel and change the channel as per your requirement.
  • After selecting channel, select the setting option at the top bar and select Analog Gauge editor.
  • In Analog Gauge editor, there are tons of customizable options, with a handy preview area.
Note : For more information, Click here
Digital Gauges
Customizing Digital Gauges.gif For customizing Digital gauges, follow the instructions given below
  • After selecting channel, select the setting option at the top bar and select Digital Gauge editor.
  • In Digital Gauge editor, there numerous customizable options available
Dashboard Alerts
  1. Use the central alerts editor
  2. Edit alerts from gauges
  • Access the dashboard settings by clicking on the gear icon.
  • In the Alert rule tab, users can configure the alert active range, alert active after time, alert deactivate after time, and can also select the notification methods (Popup "Alert" or "Set Gauge color").
Customize Notification
  • Popup Alert notification: users can customize the message and color of alert by clicking on " add new action> selecting Popup: "Alert" > and change the message and color as per their need.
  • In Set Gauge color: users can customize the color of gauge by clicking on " add new action> selecting Set Gauge Color > Color
  • Edit a gauge
Customizing your dashboard
  1. Unlock the dashboard page by unlocking the gear icon present at the top right corner
  2. After unlocking the gauge icon, open the gauge icon by clicking the gear icon.
  3. In the add gauge option, select the gauge type, channel type, and configure the gauge setting as per your requirements.
Note : For create a data-driven color-changing dashboard background Check Here Good to Know.png
Saving your dashboard
  • Click the gear icon at the top right corner to unlock the dashboard.
  • Click the save icon.
  • Under the "Create New" tab, press "New."
  • Provide a name for your dashboard and save it.
Analysis
Loading a Session:
Users can load sessions by:
  • Pressing the (+) button at the bottom of the pop-out list of laps.
  • Alternatively, press the gear icon on the dashboard and select 'Sessions'.
Importing a Session:
  • On the home screen, click on the 'Analysis' option.
  • Press the (+) button at the bottom of the pop-out list of laps.
  • A new tab will open; in this new tab, select the 'Import Log' option.
  • Under 'Import Log,' press the 'Select' option under Datalog file and import the log file.
Note: Users can also import datalog video files by clicking the 'Select' option under Datalog Video file.
Navigating data
Cursor across line chart
Playback Control
Zooming
Performance Metrics
Racecapture app provides users with plenty of performance metrics options to comprehensively analyze the performance of your cars and optimize your driving strategy. The table below provides a detailed explanation of a few important available metric:
Performance Metrics
Matric Description
AccelX, AccelY, AccelZ Lateral, Longitudinal & Vertical acceleration in X, Y and Z axis
Battery Battery voltage level
Brake Brake position
CurrentLap Current lap number
ElapsedTime Time elapsed since the start of the session
EngineTemp Temperature of Engine
GPSQual GPS quality status
Gear Current gear position
LapCount Total laps completed
LapTime Time taken for the current lap
MAP Manifold absolute pressure
MaxRpm Maximum RPM reached
OilPress Engine oil pressure
Pitch Angular orientation around the X-axis
PredTime Predicted lap time based on the current performance
RPM Engine revolutions per minute
Roll Angular orientation around the Y-axis
ShiftLight Status of the shift light
SessionTime Total time elapsed in the current session
TPMSVoltLF, TPMSVoltLR, TPMSVoltRF, & TPMSVoltRR Tire Pressure Monitoring System voltages of Left front, Left Rear, Right front & Right rear tires respectively
TPressLF, TPressLR, TPressRF, & TPressRR Tires Pressure of Left front, Left Rear, Right front & Right rear tires respectively
TireITmpLF, TireITmpLR, TireITmpRF, & TireTmpRR Internal tires temperature of Left front, Left Rear, Right front & Right rear tires respectively
Utc Coordinated Universal Time
In addition to the previously mentioned metrics, offers a diverse range of performance metrics for a comprehensive analysis of your vehicle's dynamics. These include:
Position and Timing Metrics:
  • CurrentLap
  • Distance
  • SessionTime
  • TnSlapTime
Geospatial Metrics:
  • Latitude
  • Longitude
  • GPSQual (GPS Quality)
  • GPSSATS (Number of GPS Satellites)
Competition Metrics:
  • CompAhead (Comparison Ahead)
  • CompBehind (Comparison Behind)
  • CompFlag (Competition Flag)
  • GapAhead
  • LapsAhead
  • LapsBehind
Dynamic Metrics:
  • GsumMax (Maximum G-force)
  • GsumPct (Percentage of Maximum G-force)
  • Interval
Predictive Metrics:
  • PredTime (Predicted Lap Time)
It's important to note that many of these metrics become available when related sensors are connected to the system. The RaceCapture app comes equipped with built-in default sensors, providing a foundational set of metrics:
  • Position (Latitude / Longitude): Derived from the GPS sensor, offering accurate location data.
  • Speed: Provided by the GPS sensor, delivering real-time speed information.
  • IMU (Accelerometer and Gyro): Three channels each, offering essential data on acceleration and rotation.
  • Battery: Monitors the voltage level, providing insights into the power status of the system.
  • OBDII Channels: When plugged into a vehicle with OBDII support, additional channels become available. These channels may vary based on the vehicle, but by default, TPS (Throttle Position Sensor), EngineTemp (Engine Temperature), and RPM (Revolutions Per Minute) are consistently accessible.
Each metric provides a unique perspective on your vehicle's performance, allowing for a nuanced analysis to refine your racing strategy.
Selecting Performance Metrics
To choose and display specific performance metrics on your dashboard, follow these steps:
  • Unlock the gear icon present at the top right corner
  • Click on the gear icon and select the add gauge option
  • Pick the gauge type that suits your analysis needs (e.g., digital, analog, linear chart).
  • Within the chosen gauge type, select the "Channel" representing the performance metric you want to analyze.
  • Fine-tune the settings to align with your requirements. Adjust parameters such as scale, range, or units based on your preferences.
  • Save your gauge configuration to apply the selected performance metrics to your dashboard.
By following these steps, you can tailor your dashboard to showcase the specific performance metrics that matter most to your racing analysis.
Data Visualization
Racecapture app provides innovative data visualization features, empowering users with advanced features for in-depth analysis. The table below provides a detailed explanation of available gauges:
Data Visualization Options
Gauge Type Description
Analog Visualize data with analog-style gauges for a real-time, dynamic display.
Bargraph Use bar graphs to represent data discretely, providing a clear insight of data.
Bitmap Display custom images or icons to enhance the visual representation of your data.
Digital Showcase numerical data in a clear and precise digital format for quick reference.
Heat Chart Gain insights into data patterns using color gradients to represent varying intensities.
Histogram Understand data distribution through histogram charts, ideal for analyzing frequency.
LapTime Focus on lap-specific metrics with dedicated gauges for lap time analysis.
Line Chart Track trends and variations over time using line charts for comprehensive data analysis
Overview Get a holistic view of your racing data with overview gauges summarizing key metrics.
Raw Channel Provides an unfiltered analysis of individual parameters.
Scatter Plot Identify correlations and relationships between two variables using scatter plots.
Thermal Image Visualize temperature variations with thermal image gauges for heat-sensitive data.
Time Delta Analyze time differentials between specific data points using time delta gauges.
Time Gap Evaluate time gaps for strategic decision-making.
Track Map Navigate your racing data on a track map, providing a spatial context to your analysis.
Video Integrate video data seamlessly with dedicated video gauges for synchronized analysis.
Users can explore the above mentioned gauge types to enhance their data visualization experience and get valuable insights.
Selecting Gauge Type
Users can select the desired gauge type by following the steps given below:
  • Pick the gauge type that suits your analysis needs (e.g., digital, analog, heart chart).
Customizing Views
The RaceCapture app provides numerous customization options, allowing users to configure the app interface as per their preferences. Explore the key customization features below:
Gauge Customization
  • Size, Shape, Type: Modify the size, shape, and type of available gauges to suit your visual preferences.
  • Color and Appearance: Personalize the color scheme and appearance of each gauge for a customized display.
Gauge Placement
  • Location Customization: Users can move gauges to their preferred locations on the display
  • Position Setting: Set gauges precisely where you need them for an intuitive and efficient layout.
Layer Management
  • Bring to Front or Send to Back: Adjust the layering of gauges with options to raise or lower their appearance.
  • Raise to Top or Lower to Bottom: Adjust the visibility of gauges by bringing them to the forefront or placing them at the back.
Zoom Functionality
  • Zoom In & Zoom Out: For enhancing focus, users can Zoom-in and Zoom out gauge as per requirement.
Alert Customization
  • Set Custom Alerts: Define alerts based on specific conditions or events during your race.
  • Threshold Adjustments: Configured alert thresholds to match your required value.
Advanced Features Exploration
  • Video Integration: Seamlessly integrate video data for synchronized analysis with racing telemetry.
  • Thermal Imaging: Users can use the advance feature of thermal imaging for a more comprehensive understanding of your racing data.
Regular Upgradation
  • Continuous Refinement: Users can regularly assess and fine-tune their dashboard layout and configurations based on changing preferences and real-time racing needs.
User can experiment with different configurations to find the setup that enhances their racing strategy and overall performance.
Comparative Analysis
RaceCapture app also provides advance comparative analysis options which help users to gain deeper insights into their performance over multiple laps. If your data includes lap times, this feature becomes a valuable tool in refining your racing strategy. Here's how users can take the advantage of the Comparative Analysis option:
Navigate to Comparative Analysis:
  • Access the Comparative Analysis feature by selecting the laps dropdown list on the right side of the interface.
Select Laps for Comparison:
  • Choose the laps you wish to compare from the available dropdown list.
  • Users can compare up to 4 laps simultaneously, whether they are from the same session or different sessions.
Comprehensive Lap Comparison:
  • Use the Comparative Analysis option to comprehensively assess different laps.
  • Identify trends, analyze variations, and pinpoint areas for improvement in your driving performance.
Performance Shortcomings Analysis
  • Uncover performance shortcomings by comparing key metrics across selected laps.
Session-to-Session Comparison:
  • Compare laps from different sessions to track your progress over time.
Advance Analysis Tools:
  • Users can use advance gauges and video playback, for a holistic understanding of their racing performance.
Android
iOS
System Setup
Explanation of buttons
App Preferences
On the App preferences section, users can customize various settings as per their requirements. The setting options are as follows:
  • Startup Screen: From the startup screen option, users can select any of the following as the startup screen " Homepage, dashboard, Setup & Analysis.
  • Record Session: Users can toggle the recording of sessions on or off based on their preference.
  • Send Telemetry: Control the transmission of telemetry to the Podium app (App will not send the telemetry if the device built-in telemetry module in on)
  • Connection Type: Switch between USB and Wifi as the RaceCapture device connection type.
  • Full Screen Users can enable the full screen mode of the app by turning on the full screen option present at the bottom
On the Race Tracks page you can create a custom track, which will be included in the library of track maps for automatic detection. Follow these steps to set up your custom track:
Disable Automatic Race Track Detection:
  • To create a custom track, turn off 'Automatic race track detection' option present at the top right corner
Add a New Track
  • Press the add (+) button, present at the bottom left corner, to begin the process of adding a new track to the library.
Choose Track Style
  • Upon selecting to add a new track, opt for either a circuit or Autocross (point-to-point) style course.
Select Start and Finish points
  • Follow the prompts to choose the start and finish points of your track. Drive to the desired start line and press start. You can either finish immediately to create a simple track map with a single start/finish point or proceed to create more complex configurations.
Drive Through the Track
  • Drive through the track as you've configured, ensuring to drive a sufficient distance away from the start/finish point before returning.
Confirm Track Creation
  • Confirm your track creation by following on-screen instructions. You may choose to create a minimal track with just a start/finish point
Name Your Track
  • Give your track a name and finish the setup process
By following the above mentioned simple steps, you can easily set up a custom track and can optimize your racing performance.
NoteGood to Know.png: For further details, Click Here
The GPS page allows user to configure different parameters according to their preferences. Here's a guide on adjusting GPS settings:
GPS Sample Rate
  • Adjust the GPS sample rate according to your preference. Options include 1Hz, 5Hz, 10Hz (default), 25Hz, and Disable. A 10Hz sample rate is recommended for the best balance of performance and accuracy.
Units Selection
  • Choose between imperial and metric units based on user's measurement preferences.
Channel Configuration
  • Enable or disable specific GPS channels as per user's requirements. Channels include Position, Speed, Altitude, Satellite, GPS Fix Quality, and Dilution of Precision (DOP).
By customizing these GPS settings, users can ensure accurate data capture and enhance the overall precision of their RaceCapture system.
In this section, users can customize the behavior of the lap timer and predictive lap timer. Also, there's an option to choose between metric and imperial units for calculating distance. Follow these instructions to set your race timing preferences:
Enable/Disable Lap Timer
  • Toggle the lap timer on or off based on your preference.
Enable/Disable Predictive Lap Timer
  • Choose to activate or deactivate the predictive lap timer as desired.
Distance Unit Selection
  • Opt for metric or imperial units for calculating the distance channel.
Note Important Symbol.png: It is recommended to leave these features 'on' to fully utilize the capabilities of the lap timer and predictive lap timer.
By configuring these settings, users can customize the race timing features according to their specific needs and preferences.
This section empowers users to configure and calibrate their analog sensors as per their specific requirements. To set up analog sensors, follow these straightforward steps:
  • Channel Selection: Begin by selecting the desired channel type (sensor) for configuration
  • Sample Rate Configuration: Configure the sample rate to suit your preferences and data acquisition needs.
  • Mode Selection: Choose from three available modes: Raw, Linear, or Mapped, based on your intended use.
  • Linear Formula or Interpolated Mode: In the selected mode, input values in either linear formula or interpolated mode, depending on your Mode Selection.
By following these steps, users can configure and calibrate analog sensors to optimize their performance within the RaceCapture system
Note Good to Know.png: For more details regarding the calibration of analog sensors, please visit Calibrating Analog Sensors
Pulse/RPM sensors
This section provide user the option to configure and calibrate RPM and pulse-type sensors, including those for wheel speed. Similar to the analog sensor configuration, this section allows users to:
Channel Selection
  • Choose the appropriate channel for the RPM or pulse-type sensor configuration.
  • Configure the sample rate according to your specific requirements for accurate data capture.
Channel Mode Options
  • Select the desired channel mode from RPM, Frequency, and Period (in milliseconds and microseconds).
Timer Speed Adjustment
  • Adjust timer speed with options such as slow, medium, and fast to match your sensor's characteristics.
Pulses Per Revolution
  • Specify the number of pulses per revolution for precise sensor calibration.
By utilizing these configuration options, users can effectively calibrate RPM and pulse-type sensors as per their specific needa.
Digital In/Out
This section provide user the option to configure the General Purpose Input/Outputs (GPIOs) for their RaceCapture system. In this section users can adjust the sample rate and specify whether the mode should be set to input or output.
By following these straightforward steps, users can configure the digital input/output settings to meet their specific requirements within the RaceCapture system.
For optimal performance, it is recommended to mount RaceCapture square with the chassis, ensuring that the harness connectors face the front of the vehicle.
Channel Remapping
  • Users have the flexibility to re-map channels by reassigning the physical axis to the mapped channel, offering customization based on specific needs.
Calibration Process
  • Define the desired channel mappings
  • Calibrate the accelerometer and gyro by pressing the dedicated calibrate button.
  • Confirm the calibration by pressing the write button to save the settings back to RaceCapture.
CAN bus mapping
See our comprehensive guide on Using and mapping CAN bus sensor data Good to Know.png
User can configure the OBDII channels setting and add a new OBDII channel within this section. To add a new OBDII channel To add a new OBDII channel, follow the instructions below:
Adding OBDII Channel
  • To add a new OBDII channel, click on the + button present at the bottom
Selecting OBDII channels
  • Access the channel menu and choose the desired OBDII channel from the standard list available on the OBDII configuration screen.
  • Select the sample rates from the Rate icon present in the Channel menu.
  • Note Good to Know.png: For channels that require a faster response rate, like RPM and TPS, we recommend 10, 25 or 50Hz. More slowly changing channels like EngineTemperature should be set to 1 or 5Hz.
Note about unsupported channels If your ECU does not support a channel, the value will remain at 0. RaceCapture will time-out waiting for a response from the ECU, which will affect the performance of other channels. We recommend removing all unsupported channels to ensure optimal OBDII performance.
The OBDII section offers extensive customization options, including unit conversions, mode, and PID customization. For additional information, visit Here Good to Know.png
Automatic Control
The automatic control section provides user with various options to customize their RaceCapture system's behavior. Within this section, users can:
Start/Stop Trigger Time
  • Set the trigger time for starting and stopping
Logging Triggers
  • Enable or disable SD card and app logging triggers.
Camera Control
  • Toggle camera on/off as per the requirements
Camera Type Selection
  • Choose the desired camera type directly from this section
By utilizing these options, users can configure the automatic control settings to suit their specific requirements within the RaceCapture system.
The Wireless section offers a range of configuration options for Bluetooth, WiFi, and cellular settings.
Bluetooth
In the Bluetooth section, users can toggle Bluetooth on/off, and customize the Bluetooth name and passcode.
WiFi
In wireless section, users can enable / disable wireless support and can configure RaceCapture's WiFi for both Access Point and Client mode.
Client Mode: To enable client mode, specify the SSID and password for the network you wish to connect to and turn the client mode switch to on
Access Point Mode: To enable the RaceCapture access point, specify the SSID and a password.
Cellular Configuration
This section enables users to enable/disable the on-board cellular option, select the designated regional profile, and configure the Access Point Name (APN).
By utilizing these wireless configuration options, users can configure their RaceCapture system to integrate with various networks.
With the real-time telemetry feature you can live-stream your data to Podium so you can compare and share laps and runs with your friends. Enable by setting your Podium Device ID provided by your Podium Account [File:Good to Know.png|20px]]
Scripting
Diagnostic Logs
Firmware
Steps to recover:
  • Connect RaceCapture via USB
Extra Information
Microsoft Windows 7/8 Driver installation Good to Know.png
