RaceCaptureTrack MK4
Revision as of 09:46, 10 January 2026 by Abdurrehman Akhtar (talk | contribs)
Quick Start Guide
Connecting the Hardware
Mounting
To ensure optimal performance, mount the RaceCapture system on a flat, level surface within the vehicle, with the connectors oriented toward the front. This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
Note: If it is necessary to install the unit in an alternative orientation (e.g., vertical, on-edge, or upside down), ensure it is rotated in clean 90-degree increments relative to the vehicle’s primary axes. Avoid mounting the device at an arbitrary angle, as this can affect sensor accuracy. For non-standard orientations, remap the accelerometer and gyroscope axes in the Setup menu to reflect the installed position.
Connectors
  • RP-SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
Powering up the Module
The RaceCapture/Track MK4 can be powered using the following methods: USB Power (USB Type-C) You may power the device via the USB Type-C port using any of the following sources:
  • A computer USB port
  • A USB car charger
  • A USB battery pack
This method is ideal for quick setup, bench testing, or configuration. Vehicle Power via OBD-II (CAN1 / Power) Alternatively, you can power the module using the vehicle’s OBD-II port by connecting through an OBD-II to M8 4-Pin Female Connector.
Windows / MacOS / Linux
  • Connect your Podium Connect Micro to your computer with the USB cable,
  • Start the RaceCapture app.
Android / iOS
On Raspberry Pi
  • On Android devices, you can also pair via Bluetooth using the default PIN 1234. This can also be changed later in Setup > Wireless.
First Time Wizard Setup
The RaceCapture app will guide you through a brief automated setup and tour. During this process the connection to RaceCapture/Track MK4 will be verified.
Configure System Presets
Select Favorite Race Tracks
LED Status Indicators
LED Function
GPS Indicates GPS status:
Comprehensive Setup Guide
Data System Cable Connection
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
1 CAN 1 Low
2 CAN 2 Low
3 CAN 2 High
4 Ground
5 CAN 1 High
6 Power 9–24V / 1A (~12W)
The RaceCapture/Track MK4 supports plug-and-play OBD-II connectivity along with dual CAN bus network support, enabling seamless integration with both OEM and aftermarket ECUs.
CAN Channel Mappings
CAN Bus Configuration
640PX
Driver ID
Heart Rate Monitoring
Setup Instructions
To Verify:
Racecapture
Podium
Telemetry and Logging Setup
Enabling WiFi Telemetry
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
