PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
First time setup wizard
Select your favorite Tracks
Create an account on Podium / Setting Device ID
Select your cell provider
Freedom Pop
Further Setup
Connecting your Data System
Testing Telemetry
Install your SIM card
Verifying
Installing the unit
Using Podium
See the guide on using Podium, which includes a video guide
