PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
First time setup wizard
Select your favorite Tracks
Create an account on Podium / Setting Device ID
Select your cell provider
Freedom Pop
Further Setup
Connecting your Data System
At minimum, PodiumConnect requires the following data from the connected data system:
- Speed
- GPS data
- Latitude
- Longitude
These channels allow PodiumConnect to calculate lap timing, which creates the context for analysing additional sensor data, such as temperatures, TPS, RPM, oil pressure and so on. Without these channels, telemetry will not work properly.
Testing Telemetry
Install your SIM card
Verifying
Installing the unit
Using Podium
