RacecapturePro MK3 hardware install
(=Installation=
Mounting Orientation
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Mounting Dimensions
(Click to zoom)
Main Connector
Power | |
Connection | Color |
12v | Red |
Ground | Black |
Frequency / RPM sensor inputs | |
Blue | Frequency / RPM input 1 |
Blue / White stripe | Frequency / RPM input 2 |
Blue / Green Stripe | Frequency / RPM input 3 |
Blue / Orange Stripe | Frequency / RPM input 4 |
Voltage Reference | |
Yellow | +5v reference |
Analog Sensor Inputs | |
White | Analog Input 1 |
White / Black Stripe | Analog Input 2 |
White / Orange Stripe | Analog Input 3 |
White / Blue Stripe | Analog Input 4 |
White / Gray Stripe | Analog Input 5 |
White / Green Stripe | Analog Input 6 |
White / Red Stripe | Analog Input 7 |
White / Brown Stripe | Analog Input 8 |
General Purpose Input / Output (GPIO) | |
Gray | GPIO 1 |
Gray / White Stripe | GPIO 2 |
Gray / Blue Stripe | GPIO 3 |
Auxiliary Serial Input | |
Purple / White Stripe | Auxiliary RS232 Serial TX |
Purple | Auxiliary RS232 Serial RX |
CAN Bus | |
Orange / Blue Stripe | CAN 1 High |
Orange | CAN 1 Low |
Orange / Green Stripe | CAN 2 High |
Orange / White Stripe | CAN 1 Low |
Plug Connector Type
Other connector sources
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
Connection | CAT5 EIA-T568B RJ45 cable |
+12v | Brown |
Ground | Orange/White |
CAN 1 High | Orange |
CAN 1 Low | Green/White |
CAN 2 High | Blue |
CAN 2 Low | Blue/White |
Powering
Power requirements
Voltage | 12-24v |
Fused circuit | 5A max |
Analog Sensor inputs
Voltage Range | 0-5v |
Input Impedance | Greater than 1M ohm |
Voltage protection | 400v (intermittent) |
ADC precision | 12 bit SAR |
Maximum Sample Rate | 1000Hz (logging to SD card) |
Mapping supported | Raw voltage / linear formula / interpolated map |
Connecting Sensors
Voltage Range | 0-12v |
Mapping supported | RPM / Frequency / Period |
Signal input quality
Special note about RPM inputs
- If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
GPIO
Output mode type | Open Drain (connects ground when activated) |
Input voltage protection | 0-40v - inductive protection up to 1A |
Input Mode
Output Mode
When configured for output mode, RaceCapture can sink a 1A load per port, suitable for driving indicators, relays, sending signals to other systems and driving small devices.
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
CAN channels | 2 |
CAN Baud Rate | 125K, 250K, 500K, 1M Baud |
CAN Filters | 14 per channel |
CAN bus compatibility | CAN 2.0 compatible, 1M baud |
Auxiliary Serial
- See the Lua scripting guide and Examples
