RacecapturePro MK3 hardware install
Revision as of 22:09, 26 July 2019 by Sbarton (talk | contribs) (→GPIO)
Mounting Orientation
Alternative Mounting
  • Example:
    • Upside down
    • Vertical / on edge
Mounting Dimensions
(Click to zoom)
Main Connector
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
Other connector sources
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Powering
Power requirements
Power requirements
Voltage 12-24v
Fused circuit 5A max
Powering Notes
  • You can also power via the RJ45 connector, useful when plugging in to OBDII.
  • Power can not be passed between RJ45 and the main connector, to prevent backfeeding of circuits in the vehicle.
Analog Sensor inputs
Analog channel specifications
Voltage Range 0-5v
ADC precision 12 bit SAR
Connecting Sensors
Voltage Range 0-12v
Signal input quality
Special note about RPM inputs
Connecting Sensors
GPIO
GPIO channel specifications
Input Mode
Output Mode
When configured for output mode, RaceCapture can sink a 1A load per port, suitable for driving indicators, relays, sending signals to other systems and driving small devices.
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
CAN channel specifications
CAN channels 2
CAN Filters 14 per channel
Auxiliary Serial
