RacecapturePro MK3 hardware install
Mounting Orientation
- Once mounted, you can zero out the channels by performing the calibration in Setup / Accel/Gyro.
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Mounting Dimensions
(Click to zoom)
Main Connector
| Power | |
| Connection | Color |
| 12v | Red |
| Ground | Black |
| Voltage Reference | |
| Yellow | +5v reference |
| Analog Sensor Inputs | |
| White | Analog Input 1 |
| Gray | GPIO 1 |
| Auxiliary Serial Input | |
| CAN Bus | |
| Orange | CAN 1 Low |
Plug Connector Type
Other connector sources
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
| CAN 2 High | Blue |
| CAN 2 Low | Blue/White |
Powering
Power requirements
| Voltage | 12-24v |
| Fused circuit | 5A max |
Powering Notes
- You can also power via the RJ45 connector, useful when plugging in to OBDII.
- Power can not be passed between RJ45 and the main connector, to prevent backfeeding of circuits in the vehicle.
Analog Sensor inputs
| Voltage Range | 0-5v |
Note: You can use an analog port to monitor the states of 12v switches, lights, or other 5v-12v On/Off devices. It is recommended that you use a 10K 1/4 watt resistor inline. Map the input to 0-3.0v = 0; and 3.01V+ = 1. Even if 12v is applied, ~5V will be the max displayed.
Connecting Sensors
| Voltage Range | 0-12v |
Signal input quality
Special note about RPM inputs
- If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
GPIO
| Output mode type | Open Drain (connects ground when activated) |
| Input voltage protection | 0-40v - inductive protection up to 1A |
Input Mode
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
| CAN channels | 2 |
| CAN bus compatibility | CAN 2.0 compatible, 1M baud |
Auxiliary Serial
- See the Lua scripting guide and Examples
