RaceCapture App User's Guide
First time setup
When you run RaceCapture for the first time, you are presented with a first time setup wizard. Follow this guide to set up your device.
  • Note: You can access first time setup again by navigating to the main Setup page.
Navigating Dashboard Pages
Importing a new dashboard
You can add additional dashboard pages by browsing a list of system-provided dashboard templates, or import dashboards designed by other racers like you.
To edit a gauge:
  • Unlock the dashboard
    • Display channel
    • Color
    • Min/Max range
Dashboard Alerts
Use the central alerts editor:
  • Go into dashboard settings by pressing the gear icon
Edit alerts from a gauge:
  • Edit a gauge
Customizing your dashboard
Saving your dashboard
Predictive Lap timing
Analysis
  • Note: The system default is to trigger on Speed
Navigating data
Cursor across line chart
Playback Control
  • Zooming For line charts, you can zoom on the data using a two-finger pinch gesture, or using the mouse scroll wheel or your laptop's trackpad scroll gesture.
Selecting time vs distance
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  • Linux: currently supported by running from source
  • OSX - beta support
Planned support:
Downloads
Check out some kickass features:
Capable of running on Windows and Android, the new RaceCapture app will ultimately combine RaceAnalyzer and the current Mobile app into a unified configuration, dashboard and analysis solution.
The latest race track configurations can be automatically downloaded and synchronized from http://www.race-capture.com via the application. If your track is not in the list, email us at [email protected] and we will work to get it added.
Manual Track Configuration
You can manually specify start/finish lines for custom track configurations.
  • On the Race Track sectors page set Automatic Track Detection to Off
  • For circuit type racing, set Separate start and finish lines to Off
  • Click on the gear icon to the right of the Start/Finish configuration line
  • Minimum Configuration
    • Set the latitude / longitude point of the start finish line in the Start/Finish section
  • Sector Configuration
    • Set additional sector points ordered in the direction of travel on the track.
Multi-Sector Timing
  • sectorTime - indicates the time of the last completed sector
  • sector - indicates the last completed sector
Separate Start/Finish Lines
To enable auto-x/rally/hillclimb scenarios we've enabled the ability to define a separate start and finish line.
Predictive Lap Timing
CAN bus expansion
OBD2 support
Virtual Channels
  • Detecting gear based on RPM and speed ratios
  • Turbo intercooler efficiency by calculating the difference between inlet and outlet temperature probes
  • A calculated 'engine load' indicator by integrating RPM + Manifold Pressure Sensor value.
Lua Scripting CAN bus API
Lua Scripting
  • Use the print() and println() to print out log messages which will show up in the scripting view. Great for debugging.
  • If a wayward script somehow crashes the firmware, the RCP watchdog will fire and start up RCP in safe mode, illuminating the red LED and bypassing script execution. Then, you'll have a chance to make fixes.
  • Functions have been streamlined and normalized for consistency. Additional Lua functions have been added to support virtual channels, OBDII and CAN bus messaging.
Read more in our Lua Scripting Guide
Improved log timing accuracy
  • Note, Due to the significant changes in the firmware, the RaceCapture .rcap configuration files are not compatible with the new configuration file format
Application
Install the RaceCapture app after downloading the setup package from the downloads section
Running
Editing Configuration
Auto track detection
  • Note: For the first time running you will need to download the latest set of race tracks by touching the cloud icon in the lower right corner of the app.
GPS Configuration
  • Note: Leave the Position, Speed, Distance, and Time of Day channels enabled for accurate analysis.
Analog Channels
  • Raw value
  • Simple linear scaling
  • Interpolated map
  • Note Channel #8 is fixed as a battery input channel and should not be changed.
Pulse/RPM Sensors
  • Channel Operation Mode: RPM, frequency, or pulse period
  • Clock divider: This specifies the operating range for measuring the pulse. This is typically left at 128.
  • Pulse Per Revolution / Teeth Per Wheel: This specifies the number of pulses representing a complete revolution of the wheel.
    • For RPM mode This value is typically set based on the number of cylinders and the number of coil packs used on the engine
Digital In/Out
  • Mode: Set the channel to input for reading digital on/off sensors, or output to use the channel in output mode to control a device.
Accelerometer/Gyro
Pulse/Analog Out
  • Output Mode Select either Frequency / Pulse Width Modulated (PWM) mode or analog output mode. MK1 only: to enable analog mode you also need to flip the hardware dip switch on the RaceCapture/Pro main board.
  • Logging Mode Select either logging the frequency or the analog output voltage.
  • Startup Duty Cycle The default duty cycle when the system starts up.
  • Startup Period The default startup value for the pulse period. A larger number means individual pulses are spread further apart.
CAN Bus
OBD II
