RaceCapture App User's Guide
Revision as of 22:46, 21 January 2024 by Abdurrehman Akhtar (talk | contribs)
About the guide
Navigation
Home View
  • Analysis
  • Dashboard
  • Setup
Navigate through the app
Compatible OS
How to Install
On Desktop
On Raspberry Pi
Icons Used in Manual
Icon Description
Important information
Good to Know
Mandatory action
Help
Setup Wizard
Upon running the RaceCapture app for the first time, you are presented with a first time setup wizard. Follow the steps given below to configure your device..Mandatory Action.jpg
Welcome Page:
  • Click 'Next' on the welcome page to proceed to the device setup.
Device Selection:
  • Choose your RaceCapture device from the provided list.
  • Click 'Next' to move to the connection page.
Connection Setup:
  • Connect your system to the USB port.
  • Wait for the connection to establish; your device will be recognized once connected.
NoteGood to Know.png: You can access first time setup again by navigating to the main Setup page and selecting First time setup (as shown in the instruction below)
Navigating Dashboard Pages
Importing a new dashboard
  • Click on the gear icon located at the top right corner, and select the rectangular 'Add' icon.
  • In the 'Add' icon, you'll find three options:
    • System
    • Your
    • Shared
  • Choose your preferred option and scroll down to explore the available dashboard templates.
  • Press 'Select' next to the desired dashboard template to import it.
To edit a gauge:
  • Unlock the dashboard
    • Display channel
    • Color
    • Min/Max range
Analog Gauges
  • Press the gear button on the gauge and select the edit option
  • From the top bar, select the Channel and change the channel as per your requirement.
  • After selecting channel, select the setting option at the top bar and select Analog Gauge editor.
  • In Analog Gauge editor, there are tons of customizable options, with a handy preview area.
Note : For more information, Click here
Digital Gauges
Customizing Digital Gauges.gif For customizing Digital gauges, follow the instructions given below
  • After selecting channel, select the setting option at the top bar and select Digital Gauge editor.
  • In Digital Gauge editor, there numerous customizable options available
Dashboard Alerts
  1. Use the central alerts editor
  2. Edit alerts from gauges
  • Access the dashboard settings by clicking on the gear icon.
  • In the Alert rule tab, users can configure the alert active range, alert active after time, alert deactivate after time, and can also select the notification methods (Popup "Alert" or "Set Gauge color").
Customize Notification
  • Popup Alert notification: users can customize the message and color of alert by clicking on " add new action> selecting Popup: "Alert" > and change the message and color as per their need.
  • In Set Gauge color: users can customize the color of gauge by clicking on " add new action> selecting Set Gauge Color > Color
  • Edit a gauge
Customizing your dashboard
  1. Unlock the dashboard page by unlocking the gear icon present at the top right corner
  2. After unlocking the gauge icon, open the gauge icon by clicking the gear icon.
  3. In the add gauge option, select the gauge type, channel type, and configure the gauge setting as per your requirements.
Note : For create a data-driven color-changing dashboard background Check Here
Saving your dashboard
  • Click the gear icon at the top right corner to unlock the dashboard.
  • Click the save icon.
  • Under the "Create New" tab, press "New."
  • Provide a name for your dashboard and save it.
Predictive Lap timing
Analysis
Loading a Session:
Users can load sessions by:
  • Pressing the (+) button at the bottom of the pop-out list of laps.
  • Alternatively, press the gear icon on the dashboard and select 'Sessions'.
Importing a Session:
  • On the home screen, click on the 'Analysis' option.
  • Press the (+) button at the bottom of the pop-out list of laps.
  • A new tab will open; in this new tab, select the 'Import Log' option.
  • Under 'Import Log,' press the 'Select' option under Datalog file and import the log file.
Note: Users can also import datalog video files by clicking the 'Select' option under Datalog Video file.
Navigating data
Cursor across line chart
Playback Control
Zooming
Performance Metrics
Racecapture app provides users with plenty of performance metrics options to comprehensively analyze the performance of your cars and optimize your driving strategy. The table below provides a detailed explanation of a few important available metric:
Performance Metrics
Matric Description
AccelX, AccelY, AccelZ Lateral, Longitudinal & Vertical acceleration in X, Y and Z axis
Battery Battery voltage level
Brake Brake position
CurrentLap Current lap number
ElapsedTime Time elapsed since the start of the session
EngineTemp Temperature of Engine
GPSQual GPS quality status
Gear Current gear position
LapCount Total laps completed
LapTime Time taken for the current lap
MAP Manifold absolute pressure
MaxRpm Maximum RPM reached
OilPress Engine oil pressure
Pitch Angular orientation around the X-axis
PredTime Predicted lap time based on the current performance
RPM Engine revolutions per minute
Roll Angular orientation around the Y-axis
ShiftLight Status of the shift light
SessionTime Total time elapsed in the current session
TPMSVoltLF, TPMSVoltLR, TPMSVoltRF, & TPMSVoltRR Tire Pressure Monitoring System voltages of Left front, Left Rear, Right front & Right rear tires respectively
TPressLF, TPressLR, TPressRF, & TPressRR Tires Pressure of Left front, Left Rear, Right front & Right rear tires respectively
TireITmpLF, TireITmpLR, TireITmpRF, & TireTmpRR Internal tires temperature of Left front, Left Rear, Right front & Right rear tires respectively
Utc Coordinated Universal Time
In addition to the previously mentioned metrics, offers a diverse range of performance metrics for a comprehensive analysis of your vehicle's dynamics. These include:
Position and Timing Metrics:
  • CurrentLap
  • Distance
  • SessionTime
  • TnSlapTime
Geospatial Metrics:
  • Latitude
  • Longitude
  • GPSQual (GPS Quality)
  • GPSSATS (Number of GPS Satellites)
Competition Metrics:
  • CompAhead (Comparison Ahead)
  • CompBehind (Comparison Behind)
  • CompFlag (Competition Flag)
  • GapAhead
  • LapsAhead
  • LapsBehind
Dynamic Metrics:
  • GsumMax (Maximum G-force)
  • GsumPct (Percentage of Maximum G-force)
  • Interval
Predictive Metrics:
  • PredTime (Predicted Lap Time)
Each metric provides a unique perspective on your vehicle's performance, allowing for a nuanced analysis to refine your racing strategy.
Selecting Performance Metrics
To choose and display specific performance metrics on your dashboard, follow these steps:
  • Unlock the gear icon present at the top right corner
  • Click on the gear icon and select the add gauge option
  • Pick the gauge type that suits your analysis needs (e.g., digital, analog, heart chart).
  • Within the chosen gauge type, select the "Channel" representing the performance metric you want to analyze.
  • Fine-tune the settings to align with your requirements. Adjust parameters such as scale, range, or units based on your preferences.
  • Save your gauge configuration to apply the selected performance metrics to your dashboard.
By following these steps, you can tailor your dashboard to showcase the specific performance metrics that matter most to your racing analysis.
Data Visualization
Racecapture app provides innovative data visualization features, empowering users with advanced features for in-depth analysis. The table below provides a detailed explanation of available gauges:
Data Visualization Options
Gauge Type Description
Analog Visualize data with analog-style gauges for a real-time, dynamic display.
Bargraph Use bar graphs to represent data discretely, providing a clear insight of data.
Bitmap Display custom images or icons to enhance the visual representation of your data.
Digital Showcase numerical data in a clear and precise digital format for quick reference.
Heat Chart Gain insights into data patterns using color gradients to represent varying intensities.
Histogram Understand data distribution through histogram charts, ideal for analyzing frequency.
LapTime Focus on lap-specific metrics with dedicated gauges for lap time analysis.
Line Chart Track trends and variations over time using line charts for comprehensive data analysis
Overview Get a holistic view of your racing data with overview gauges summarizing key metrics.
Raw Channel Provides an unfiltered analysis of individual parameters.
Scatter Plot Identify correlations and relationships between two variables using scatter plots.
Thermal Image Visualize temperature variations with thermal image gauges for heat-sensitive data.
Time Delta Analyze time differentials between specific data points using time delta gauges.
Time Gap Evaluate time gaps for strategic decision-making.
Tiny Digital Optimize screen space with compact digital gauges for focused data representation.
Track Map Navigate your racing data on a track map, providing a spatial context to your analysis.
Video Integrate video data seamlessly with dedicated video gauges for synchronized analysis.
Users can explore the above mentioned gauge types to enhance their data visualization experience and get valuable insights.
Selecting Gauge Type
Users can select the desired gauge type by following the steps given below:
Customizing Views
The RaceCapture app provides numerous customization options, allowing users to configure the app interface as per their preferences. Explore the key customization features below:
Gauge Customization
  • Size, Shape, Type: Modify the size, shape, and type of available gauges to suit your visual preferences.
  • Color and Appearance: Personalize the color scheme and appearance of each gauge for a customized display.
Gauge Placement
  • Location Customization: Users can move gauges to their preferred locations on the display
  • Position Setting: Set gauges precisely where you need them for an intuitive and efficient layout.
Layer Management
  • Bring to Front or Send to Back: Adjust the layering of gauges with options to raise or lower their appearance.
  • Raise to Top or Lower to Bottom: Adjust the visibility of gauges by bringing them to the forefront or placing them at the back.
Zoom Functionality
  • Zoom In & Zoom Out: For enhancing focus, users can Zoom-in and Zoom out gauge as per requirement.
Alert Customization
  • Set Custom Alerts: Define alerts based on specific conditions or events during your race.
  • Threshold Adjustments: Configured alert thresholds to match your required value.
Advanced Features Exploration
  • Video Integration: Seamlessly integrate video data for synchronized analysis with racing telemetry.
  • Thermal Imaging: Users can use the advance feature of thermal imaging for a more comprehensive understanding of your racing data.
Regular Upgradation
  • Continuous Refinement: Users can regularly assess and fine-tune their dashboard layout and configurations based on changing preferences and real-time racing needs.
User can experiment with different configurations to find the setup that enhances their racing strategy and overall performance.
Comparative Analysis
If the data contains lap times, the laps will be shown in the dropdown list on the right. Select the laps you wish to compare; users can compare up to 4 laps at once from the same session or different sessions.
Selecting time vs distance
Comparing laps / runs between sessions(Comparative Analysis)
Advanced Analysis Tools
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Steps to recover:
  • Connect RaceCapture via USB
Extra Information
