ESP32-CAN-X2
Purchasing
- Flexible power supply options up to 40V, suitable for automotive and industrial applications
- Reset and Boot push button
- Integrated CAN transceivers
- Comprehensive free software libraries and examples for CAN communication for Arduino and Circuit Python
- Supports a range of stackable add-on boards offering additional features such as GPS, RGB LEDs, switches, and more.
Bolt-ons
GPS bolt-on
Adds a high performance GPS receiver
Button bolt-on
Adds 4 tactile switches + RGB LEDs
RGB LED bolt-on
Adds 10 RGB LEDs across two groups for alert indicators
Getting started
Microcontroller
External Connection Header
CAN Controllers
Two 4-Pin header Connector
Built-in LED
USB-C Socket
Debug Connector
The following 6-pin connector marked as X4 is used for serial communication and debugging purposes with ESP32 CAN X2. The 6-pin configurations on the ESP32 CAN X2 is arranged as follows:
Board Layout
- Width : 42.10 mm
- Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Board Pinout
| 5 | RX Pin | USART RX |
| 6 | TX Pin | USART TX |
| 7-20 | GPIO Pins | GPIO's (3.3v tolerant; to avoid damage do not apply any higher voltages to these pins) |
| 1-11 | GPIO Pins | GPIO's (3.3v tolerant; to avoid damage do not apply any higher voltages to these pins) |
| 12-13 | 3.3V | 3.3v Voltage Output (can be used to power your custom circuits) |
| 14-15 | 5V | 5v Voltage Output (can be used to power your custom circuits) |
| 16-18 | GND | Ground |
| 19-20 | 12 Vin | 12v voltage Input |
12v note
Top Headers Pinout
| 1 | +12V_AUX | 6-12V Power Supply |
| 2 | CAN1H/2.7A | high-level signal for the first CAN channel |
| 3 | CAN1L/2.7A | low-level signal for the first CAN channel |
| 4 | GND | Ground |
| 2 | CAN1H/2.7A | high-level signal for the second CAN channel |
| 3 | CAN1L/2.7A | low-level signal for the second CAN channel |
| 4 | GND | Ground |
Flashing Firmware
Hardware Components
- USB-C cable
Software Components
Sample Arduino Project
- Open Arduino Ide
- Go to File > Preferences
Flashing
Sample CircuitPython code
Click on the browse S3
- Select the desired language
Flash the Firmware
written.
Exit Bootloader Mode
- Extract the zip file.
