RaceCaptureTrack MK4
Revision as of 16:23, 13 January 2026 by Abdurrehman Akhtar (talk | contribs)
Quick Start Guide
Connecting the Hardware
Mounting
To ensure optimal performance, mount the RaceCapture system on a flat, level surface within the vehicle, with the connectors oriented toward the front. This orientation aligns with the factory calibration of the internal accelerometer and gyroscope.
Note: If it is necessary to install the unit in an alternative orientation (e.g., vertical, on-edge, or upside down), ensure it is rotated in clean 90-degree increments relative to the vehicle’s primary axes. Avoid mounting the device at an arbitrary angle, as this can affect sensor accuracy. For non-standard orientations, remap the accelerometer and gyroscope axes in the Setup menu to reflect the installed position.
Connectors
  • SMA Antenna Connector (L5_GNSS, LTE)
Positioning the Antenna
Powering up the Module
USB Power (USB Type-C)
  • A computer USB port
  • A USB car charger
  • A USB battery pack
Windows / MacOS / Linux
  • Connect your Podium Connect Micro to your computer with the USB cable,
  • Start the RaceCapture app.
Android / iOS
On Raspberry Pi
  • On Android devices, you can also pair via Bluetooth using the default PIN 1234. This can also be changed later in Setup > Wireless.
First Time Wizard Setup
The RaceCapture app will guide you through a brief automated setup and tour. During this process the connection to RaceCapture/Track MK4 will be verified.
Configure System Presets
Select Favorite Race Tracks
LED Status Indicators
LED Function
GPS Indicates GPS status:
Telemetry indicator Indicates when real-time telemetry is actively broadcasting
Comprehensive Setup Guide
Data System Cable Connection
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
1 CAN 1 Low
2 CAN 2 Low
3 CAN 2 High
4 Ground
5 CAN 1 High
6 Power 9–24V / 1A (~12W)
M8 CAN Bus to OBD-II cable
Connection Steps
  1. Plug the M8 connector end of the cable into the CAN port on the RaceCapture/Track MK4.
  2. Connect the OBD-II connector end to the vehicle’s OBD-II diagnostic port (typically located under the dashboard).
  3. Ensure the connection is secure before powering on the system.
Vehicle compatibility
CAN Channel Mappings
CAN Bus Configuration
640PX
Driver ID
Heart Rate Monitoring
Setup Instructions
To Verify:
Racecapture
Podium
Telemetry and Logging Setup
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Firmware and Software Updates
Backing Up Configurations
  • Connect to RaceCapture/Track MK4 using the RaceCapture app - using USB, or WiFi.
Updating Firmware
  • Download the latest RaceCapture firmware from Firmware
  • Press Open
Restoring Settings
RaceCapture/Track MK4 support direct reading of compatible Bluetooth-based TPMS sensors. These sensors broadcast tire pressure and temperature data wirelessly and can be read by the device without any additional TPMS receiver hardware.Unlike older 433 MHz TPMS systems, which require a separate in-vehicle receiver module, Bluetooth TPMS sensors communicate directly with RaceCapture/Track MK4.
System Overview
Supported Features
  • RaceCapture/Track MK4 support upto 16 TPMS sensors
    • Left Front
    • Right Front
    • Left Rear
    • Right Rear
Registering TPMS Sensors
