RaceCapture-Pro MK2
Revision as of 19:25, 27 May 2013 by Brentp (talk | contribs) (→Race Capture Pro Quick Links: bolded buy link)
10Hz GPS
Rev F board
Connectors View
Terminal Block
Impact
Significance
Flexibility
On-board scripting
Some Examples:
Software Connectivity
  • Customize logging channels
  • View Runtime Data
  • Edit custom scripting
Infinite Possibilities
Technical Specifications
Input and Output Channels
  • 10Hz GPS module input
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
  • Auxiliary Serial Port
  • Digital expansion port
    • A high speed port provides the ability to add CAN bus expansion, more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
Power
  • 48MHz 32 bit ARM processor
Input/Output Protection
  • 40v protection on all input pins
Mechanical
  • Compact, rugged design
  • On-board Status LEDs
Example Sensor Connectivity
