RaceCapture App User's Guide
About the guide
Navigation
Compatible OS
How to Install
How to Update
Icons Used in Manual
Help
Install the RaceCapture app
On Desktop
USB Drivers
  • Windows 10/11: Windows 10 has built in USB drivers that support RaceCapture; no separate driver installation needed.
  • Windows XP, 7, 8: Not supported due to outdated video drivers, but may work depending on the video hardware used. USB drivers will require installation instructions below.
On Raspberry Pi
Setup Wizard
When you run RaceCapture for the first time, you are presented with a first time setup wizard. Follow this guide to set up your device.
  • Note: You can access first time setup again by navigating to the main Setup page.
Navigating Dashboard Pages
Importing a new dashboard
You can add additional dashboard pages by browsing a list of system-provided dashboard templates, or import dashboards designed by other racers like you.
To edit a gauge:
  • Unlock the dashboard
    • Display channel
    • Color
    • Min/Max range
Dashboard Alerts
Use the central alerts editor:
  • Go into dashboard settings by pressing the gear icon
Edit alerts from a gauge:
  • Edit a gauge
Customizing your dashboard
Saving your dashboard
Predictive Lap timing
Analysis
  • Note: The system default is to trigger on Speed
Navigating data
Cursor across line chart
Playback Control
  • Zooming For line charts, you can zoom on the data using a two-finger pinch gesture, or using the mouse scroll wheel or your laptop's trackpad scroll gesture.
Selecting time vs distance
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Steps to recover:
  • Connect RaceCapture via USB
Extra Information
