RaceCapture App User's Guide
About the guide
This is a comprehensive user guide that contains complete instructions about the services and functions of the RaceCapture app. The app is designed to be easy to use, simple, and futuristic. The RaceCapture app allows you to integrate your devices with the RaceCapture modules and get instant access to the endless functionalities of RaceCapture modules. Using this app, customers can access all the features of the RaceCapture modules, monitor, store, and analyze the real-time data, and users can also provide customized commands to the RaceCapture modules using Lua scripts. Further details about the app are given in the respective sections.
Home View
- Analysis
- Dashboard
- Setup
Compatible OS
How to Install
On Desktop
On Raspberry Pi
Icons Used in Manual
Icon | Description |
Important information | |
Good to Know | |
Mandatory action |
Help
Any quire, concern or issue regarding the app may be resolved by contacting the Autosport Labs support team our support team by phone or direct email.
- @autosportlabs.com "
Setup Wizard
Upon running the RaceCapture app for the first time, you are presented with a first time setup wizard. Follow the steps given below to configure your device..
Welcome Page:
- Click 'Next' on the welcome page to proceed to the device setup.
Device Selection:
- Choose your RaceCapture device from the provided list.
- Click 'Next' to move to the connection page.
Connection Setup:
- Connect your system to the USB port.
- Wait for the connection to establish; your device will be recognized once connected.
Note: You can access first time setup again by navigating to the main Setup page and selecting First time setup (as shown in the instruction below)
Importing a new dashboard
- Click on the gear icon located at the top right corner, and select the rectangular 'Add' icon.
- In the 'Add' icon, you'll find three options:
- System
- Your
- Shared
- Choose your preferred option and scroll down to explore the available dashboard templates.
- Press 'Select' next to the desired dashboard template to import it.
To edit a gauge:
- Unlock the dashboard
- Display channel
- Color
- Min/Max range
Dashboard Alerts
Use the central alerts editor:
- Go into dashboard settings by pressing the gear icon
Edit alerts from a gauge:
- Edit a gauge
Customizing your dashboard
Saving your dashboard
Predictive Lap timing
Analysis
- Note: The system default is to trigger on Speed
Cursor across line chart
Playback Control
- Zooming For line charts, you can zoom on the data using a two-finger pinch gesture, or using the mouse scroll wheel or your laptop's trackpad scroll gesture.
Selecting time vs distance
Android
iOS
System Setup
Explanation of buttons
Pulse/RPM sensors
Digital In/Out
CAN bus mapping
Automatic Control
Scripting
Diagnostic Logs
Firmware
Steps to recover:
- Connect RaceCapture via USB
Extra Information
