ESP32-CAN-X2
Revision as of 09:35, 13 December 2024 by Abdurrehman Akhtar (talk | contribs)
  • Two LED’s : Power LED and user defined LED1
  • Reset and Boot push button
  • Integrated antenna for long range communication
  • 6-pin header is strategically positioned at the top for CAN communication
  • Integrated CAN transceivers
Getting started
Figure 1
Microcontroller
Figure 2
External Connection Header
CAN Controllers
Figure 3
6 pin JST-PH Connector
USB-C Socket
Board Layout
  • Width  : 42.10 mm
  • Length : 72 mm
Figure 4
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Board Pinout
Figure 7
Pin Function Description
5 RX Pin USART RX
6 TX Pin USART TX
16-18 GND Ground
12v note
Top Header Pinout
Figure 8
1 CAN1L/2.7A low-level signal for the first CAN channel
2 CAN2L/2.7B low-level signal for the second CAN channel
3 CAN2H/2.7B high-level signal for the second CAN channel
4 GND Ground
5 CAN1H/2.7A high-level signal for the first CAN channel
6 +12V_ Aux 6-12v power supply
Flashing Firmware
Hardware Components
  • USB-C cable
Software Components
Note : Link to download Arduino IDE : https://www.arduino.cc/en/software || Link to download Mu Editor : codewith.mu
Sample Arduino Project
  • Open Arduino Ide
  • Go to File > Preferences
Figure 7
Json URL : https://espressif.github.io/arduino-esp32/package_esp32_index.json
Figure 8
Figure 9
Figure 10
Flashing
Figure 11
Figure 12
Sample CircuitPython code
Installing ESP-32-X2 is simple, please follow the steps given below :
Click on the browse S3
  • Select the desired language
Flash the Firmware
written.
Exit Bootloader Mode
Importing libraries in Circuitpython is straightforward. For installing Libraries in Circuitpython, please follow the steps given below :
  • Extract the zip file.
Bolt-ons
ESP32-CAN-X2 Rev C
