ESP32-CAN-X2
- Reset and Boot push button
- Integrated CAN transceivers
Getting started
Microcontroller
External Connection Header
CAN Controllers
6 pin JST-PH Connector
USB-C Socket
Board Layout
- Width : 42.10 mm
- Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Board Pinout
| 5 | RX Pin | USART RX |
| 6 | TX Pin | USART TX |
| 7-20 | GPIO Pins | GPIO's (3.3v tolerant; to avoid damage do not apply any higher voltages to these pins) |
| 1-11 | GPIO Pins | GPIO's (3.3v tolerant; to avoid damage do not apply any higher voltages to these pins) |
| 12-13 | 3.3V | 3.3v Voltage Output (can be used to power your custom circuits) |
| 14-15 | 5V | 5v Voltage Output (can be used to power your custom circuits) |
| 16-18 | GND | Ground |
| 19-20 | 12 Vin | 12v voltage Input |
12v note
Top Header Pinout
| 4 | GND | Ground |
| 5 | CAN1H/2.7A | high-level signal for the first CAN channel |
Flashing Firmware
Hardware Components
- USB-C cable
Software Components
Sample Arduino Project
- Open Arduino Ide
- Go to File > Preferences
Flashing
Sample CircuitPython code
Click on the browse S3
- Select the desired language
Flash the Firmware
written.
Exit Bootloader Mode
- Extract the zip file.
Bolt-ons
