RacecaptureApex hardware install
Mounting Orientation
!!mounting orientation pic
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Main Connector
The main connector provides access to all power, sensor and communications for the RaceCapture/Apex system.
| Power | |
| Connection | Color |
| 12v | Red |
| Ground | Black |
| Voltage Reference | |
| Yellow | +5v reference |
| Analog Sensor Inputs | |
| White | Analog Input 1 |
| Gray | GPIO 1 |
| Auxiliary Serial Input | |
| CAN Bus | |
| Orange | CAN 1 Low |
Plug Connector Type
The standard Deutsch DTM connector system is used:
- DTM06-12SA
- DTM06-12SB
- Matching wedge lock (WM-12S)
- Pins 0462-201-20141
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
Powering
Connect RaceCapture/Apex to a 12v source, ideally switched with main power or via ignition power.
Power requirements
| Voltage | 12-24v |
| Fused circuit | 5A max |
Analog Sensor inputs
| Voltage Range | 0-5v |
Connecting Sensors
You can connect RPM, wheel speed and other pulse-type sensors to RaceCapture/Apex frequency input pins.
| Voltage Range | 0-12v |
Signal input quality
Special note about RPM inputs
- If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
GPIO
RaceCapture/Apex provides 3 General Purpose Input Output (GPIO) ports which you can use to control devices (Output mode) or read switches or high / low states of electrical signals.
| Output mode type | Open Drain (connects ground when activated) |
| Input voltage protection | 0-40v - inductive protection up to 1A |
Input Mode
When configured for input mode, the RaceCapture/Apex sensor input will register a '1' when the input passes a voltage threshold of approximately 3v, and '0' when the input is low (close to 0 volts).
Important Note: when sensing large inductive loads, such as sensing brake light state or sensing the on/off state of a motor, connect a 10K 1/4 watt resistor in-line with the GPIO input to protect RaceCapture/Apex from a large inductive spike.
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
| CAN channels | 2 |
| CAN bus compatibility | CAN 2.0 compatible, 1M baud |
Auxiliary Serial
One Auxiliary RS232 compatible serial port is available on the main connector. You can use this to communicate with external devices that uses RS232 serial for communications.
- See the Lua scripting guide and Examples
