RaceCapture-Track MK3
Start it up
Plug it in
- Plug one end of the OBDII cable into the RaceCapture Power/CAN port.
LED status
- CAN - Shows activity on OBDII / CAN bus network, indicating data from your ECU and sensors is being received.
- GPS - Shows GPS activity. Slow flash indicates acquiring a lock; rapid flash indicates GPS is locked.
- Error - Indicates an error condition with the unit - see the RaceCapture app status page for details. It can also indicate an error with your Lua script (an optional feature of the system)
- Power - Illuminates when the unit has power via 12v or USB.
- Very fast green flash: Very rapid green flash indicates the unit is in bootloader mode, during firmware updates. If you see this when the the unit powers up and you cannot connect with the RaceCapture app, it usually means a failed firmware upgrade. You can resolve the issue by going through the firmware update process again.
Mounting
Place the RaceCapture system on a level surface in your car, with connectors facing the front of the vehicle. This is the factory orientation for the accelerometers and gyro.
Attach GNSS antenna
Attach the GNSS (AKA GPS) antenna connector to RaceCapture and screw to 5-6 inch lbs - just beyond finger tight to prevent the connector from vibrating loose. Do not overtighten.
Locating Antenna
- Ideal: Mount the antenna on the roof of the vehicle, using the magnetic mount. Place the antenna with minimum 3 feet spacing from other transmitting antennas (car radios, cellular antennas, etc).
- Alternate Mounting: You can mount it on the dashboard in clear view of the sky, or on the rear parcel tray under the back window. Note, this may degrade your GPS performance vs. roof mounting.
Download the app
- Windows 10 and OSX: No USB drivers are needed for OSX or Windows 10.
First Time Setup
Connect the RaceCapture device to your computer via the supplied USB cable; this will also provide power to the unit. This is a good way to set up and test your RaceCapture system on the bench.
Android
We recommend connecting with Bluetooth when using Android devices.
Connecting with Bluetooth
- Ensure RaceCapture is powered.
- Note: The default password is 1234 - you can change this later under Setup.
Connecting with WiFi
- Under Android settings, navigate to the WiFi section.
- Wait until you see the RaceCapture WiFi network.
- Select this network to connect.
- Note: No password is required for the initial connection - you can set a password for your WiFi network later under Setup.
iOS
- Under your iOS settings, navigate to the WiFi section.
Extended Setup Guide
Alternative ways to power
USB
- Note: OBDII is enabled by default on CAN1; CAN2 is recommended for secondary sensor networks.
Note: Windows 7 and 8 is officially unsupported, but may still work on your computer.
Steps to recover:
- Connect RaceCapture via USB
- How to: get best GPS data
- How to update firmware
- Remote Coaching with Race Capture and Streaming Video
- How To Videos
Analog Inputs | |
Channels | Battery Voltage (Internally connected) (0-20v) |
CAN Bus | |
CAN Channels | 2 |
CAN termination | Internal jumper controlled; termination disabled by default |
Cellular Telemetry | |
Via RaceCapture App | 3G/4G depending on mobile device's capability (phone) or connected tablet + hotspot |
GPS/GNSS | |
GNSS (GPS) Engine | 1/5/10/25Hz native |
Supported Constellations | GPS, GLONASS, Beidou, Galileo |
GNSS Antenna | Triple band External / Magnetic roof mount |
Wireless (WiFI) | |
WiFi | 802.11bgn |
Wireless (Bluetooth) | |
Bluetooth (high speed) | 2.0/2.1 EDR |
General Features | |
Maximum Sample Rate | 50Hz |
Track Mapping | Circuit and point-point |
Track maps | Unlimited - update from cloud |
Sectors per track | 20 |
Analysis |
Included in the RaceCapture App + podium.live |
Export data format | Plain CSV (RaceRender and Dashware compatible) |
Scripting / Customization | |
Virtual Channels | 100 |
Physical | |
Dimensions | 85 x 90 x 35mm (3.34 x 3.54 x 1.37in) |
Environmental | IP50 rated |
Weight | 150g (5 oz) |
Physical | M8 4P connector for Power and CAN1 to ECU; M8 6P connection for CAN1 / CAN2 expansion to sensor networks |
Power Consumption (max) | 1.6W |
