ESP32-CAN-X2
  • Reset and Boot push button
  • Integrated CAN transceivers
Getting started
Microcontroller
Figure 2
External Connection Header
CAN Controllers
Figure 3
Two 4-Pin header Connector
USB-C Socket
Board Layout
  • Width  : 42.10 mm
  • Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
The ESP-32-X2 development board has given two separate CAN termination pads at the back side of the development board. The CAN termination jumpers are shown in the figure 6 given below.
Figure 6
Board Pinout
Figure 7
Pin Function Description
5 RX Pin USART RX
6 TX Pin USART TX
16-18 GND Ground
12v note
Top Headers Pinout
Figure 8
1 +12V_AUX 6-12V Power Supply
4 GND Ground
4 GND Ground
Flashing Firmware
Hardware Components
  • USB-C cable
Software Components
Note : Link to download Arduino IDE : https://www.arduino.cc/en/software || Link to download Mu Editor : codewith.mu
Sample Arduino Project
  • Open Arduino Ide
  • Go to File > Preferences
Figure 7
Json URL : https://espressif.github.io/arduino-esp32/package_esp32_index.json
Figure 8
Figure 9
Figure 10
Flashing
Figure 11
Figure 12
Sample CircuitPython code
Installing ESP-32-X2 is simple, please follow the steps given below :
Click on the browse S3
  • Select the desired language
Flash the Firmware
written.
Exit Bootloader Mode
Importing libraries in Circuitpython is straightforward. For installing Libraries in Circuitpython, please follow the steps given below :
  • Extract the zip file.
Bolt-ons
ESP32-CAN-X2 Rev-C
ESP32-CAN-X2 Rev-C
