RaceCapturePro-MK1
RaceCapture/Pro MK1 information page
Race Capture Pro Quick Links
- Super Quick Start
- Realtime Telemetry Quick Start
- Sensor Guide
- Lua Scripting Guide
- FAQ / "How Do I...?"
- Installation Guide
- Software Operation Guide
- Source code
Impact
Significance
Flexibility
On-board scripting
Some Examples:
- Activate a warning light when an input threshold is exceeded, such as temperature or pressure, or a combination of both
- Log data at a higher rate when in range of a particular GPS coordinate, or when some other condition is met
- Auto-start/stop logging based on speed, RPM, or any other condition
- Experiment with active aerodynamics by adjusting a wing based on GPS velocity
- Define logic to control an intercooler sprayer
- Intercept and remap an OEM sensor
- Activate Smoke screens against your competitors :)
Software Connectivity
- Customize logging channels
- View Runtime Data
- Edit custom scripting
- Perform data analysis and replay
Infinite Possibilities
- Far more than a data-logging system: flexible Inputs and Outputs coupled with a powerful processor offers endless customization
- Fully Open Source System - Open Standards, Open File format Frequent software updates and end-user customizable!
- Source code
Technical Specifications
Input and Output Channels
- 7 dedicated 0-5v analog input channels
- 3 dedicated 0-5v frequency input channels
- Measure RPM, wheel speed, or any kind of periodic pulse.
- 4 configurable 0-5v analog or frequency output (PWM) channels
- 3 configurable digital channels, settable for input or output
- Receive input from switches or digital signals; or configure as output and use to activate accessories or drive indicator lamps with on-board 1A self-protected mosfets
- 4 Axis Accelerometer: 3 channel accelerometer module plus Z-axis gyro (+/- 2G per axis, 3G optional)
- Measure and log 3D G-force in real-time with one of the industry's most accurate accelerometers.
- Z-axis gyroscope measures yaw/drift in real-time.
- 10Hz GPS module input
- Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
- Auxiliary Serial Port
- Interface to real time telemetry, bluetooth adapter, dashboard display or other interface
- Digital expansion port
- A high speed port provides the ability to add CAN bus expansion, more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
- Store up to 32GB of logging data
CPU
- 48MHz 32 bit ARM processor
- Enough juice to perform high resolution logging and running complex, user-defined logic
Input/Output Protection
- 40v protection on all input pins
- Analog outputs protected by auto-resettable fuses
- Digital outputs are rated at 1A with self-protected mosfets
- Over-current protection on 5V reference
- 2A internal switching power supply
Mechanical
- Compact, rugged design
- Unit measures approximately 4 x 3 inches (100 x 82 mm)
- Weighs 8.4oz
- Real-Time module weighs 7oz
- On-board Status LEDs
Power
- 9-17v power
- < 100mA for RaceCapture/Pro.
- May burst to 2A temporarily when using RealTime Telemetry module
