RaceCapture-Pro MK1
Race Capture Pro MK2 Quick Links
- Super Quick Start
- Realtime Telemetry Quick Start
- Sensor Guide
- Lua Scripting Guide
- FAQ / "How Do I...?"
- Installation Guide
- Software Operation Guide
- Source code
- Upcoming Features
Autosport Labs is excited to announce our latest project: RaceCapture/Pro mk2 - a powerful, multi-channel data acquisition and control system for motorsport applications
Impact
Significance
While the primary application of RaceCapture/Pro mk2 is focused towards race car data acquisition, its powerful processor combined with a wealth of inputs and outputs also makes RaceCapture/Pro a general purpose automotive computer, one capable of handling many different tasks - limited only by your imagination. If the question is "Can RaceCapture do ...?" the answer will likely be 'Yes' and often with little to no external hardware support necessary.
Flexibility
On-board scripting
Some Examples:
- Activate a warning light when an input threshold is exceeded, such as temperature or pressure, or a combination of both
- Log data at a higher rate when in range of a particular GPS coordinate, or when some other condition is met
- Auto-start/stop logging based on speed, RPM, or any other condition
- Experiment with active aerodynamics by adjusting a wing based on GPS velocity
- Define logic to control an intercooler sprayer
- Intercept and remap an OEM sensor
- Activate Smoke screens against your competitors :)
Software Connectivity
RaceCapture/Pro features software to:
- Customize logging channels
- View Runtime Data
- Edit custom scripting
- Perform data analysis and replay
Infinite Possibilities
- Far more than a data-logging system: flexible Inputs and Outputs coupled with a powerful processor offers endless customization
- Fully Open Source System - Open Standards, Open File format Frequent software updates and end-user customizable!
- Source code
Technical Specifications
Input and Output Channels
RaceCapture mk2 offers 21 input and output channels and serial communication port, enough to handle complex logging and control tasks.
- 7 dedicated 0-5v analog input channels
- 3 dedicated 0-5v frequency input channels
- Measure RPM, wheel speed, or any kind of periodic pulse.
- 4 configurable 0-5v analog or frequency output (PWM) channels
- 3 configurable digital channels, settable for input or output
- Receive input from switches or digital signals; or configure as output and use to activate accessories or drive indicator lamps with on-board 1A self-protected mosfets
- 4 Axis Accelerometer: 3 channel accelerometer module plus Z-axis gyro (+/- 2G per axis, 3G optional)
- Measure and log 3D G-force in real-time with one of the industry's most accurate accelerometers.
- Z-axis gyroscope measures yaw/drift in real-time.
- 50Hz GPS module
- Internal state of the art GPS module
- Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time. Real time predictive timing.
- Auxiliary Serial Port
- Interface to real time telemetry, bluetooth adapter, dashboard display or other interface
- CAN Bus Expansion
- Two high speed CAN bus ports provide the ability to virtually interface with any type of CAN bus enabled equipment, from ECUs to tire temperature sensors.
Logging
- Store up to 32GB of logging data
CPU
- 168MHz 32 bit ARM processor
- Enough juice to perform high resolution logging and running complex, user-defined logic
Input/Output Protection
- 40v protection on all input pins
- Analog outputs protected by auto-resettable fuses
- Digital outputs are rated at 1A with self-protected mosfets
- Over-current protection on 5V reference
- 2A internal switching power supply
Mechanical
- Compact, rugged design
- Unit measures approximately 4 x 3 inches (100 x 82 mm)
- Weighs 8.4oz
- Real-Time module weighs 7oz
- On-board Status LEDs
Power
- TODO ***
- 9-17v power
- < 100mA for RaceCapture/Pro.
- May burst to 2A temporarily when using RealTime Telemetry module
