RacecaptureApex hardware install
Revision as of 04:51, 11 May 2017 by Brentp (talk | contribs) (Created page with "=Installation= ==Mounting Orientation== The default and recommended mounting orientation is flat with indicators facing forward for visibility. !!mounting orientation pic...")
Alternative Mounting
  • Example:
    • Upside down
    • Vertical / on edge
Main Connector
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
The standard Deutsch DTM connector system is used:
  • DTM06-12SA
  • DTM06-12SB
  • Matching wedge lock (WM-12S)
  • Pins 0462-201-20141
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
It's recommended you separate the GPS and cellular antennas as reasonably far apart as possible, such as mounting at opposite ends of the roof. RaceCapture Pro MK3 antenna install.png
Powering
Power requirements
Power requirements
Voltage 12-24v
Fused circuit 5A max
Analog Sensor inputs
Analog channel specifications
Voltage Range 0-5v
ADC precision 12 bit SAR
Connecting Sensors
Voltage Range 0-12v
Signal input quality
Special note about RPM inputs
Connecting Sensors
GPIO
GPIO channel specifications
Input Mode
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
CAN channel specifications
CAN channels 2
CAN Filters 14 per channel
Auxiliary Serial
One Auxiliary RS232 compatible serial port is available on the main connector. You can use this to communicate with external devices that uses RS232 serial for communications.
