RacecaptureApex hardware install
Revision as of 04:52, 11 May 2017 by Brentp (talk | contribs)
Mounting Orientation
!!mounting orientation pic
Alternative Mounting
  • Example:
    • Upside down
    • Vertical / on edge
Main Connector
The main connector provides access to all power, sensor and communications for the RaceCapture/Apex system.
RaceCapture/Apex connector pinout
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
The standard Deutsch DTM connector system is used:
  • DTM06-12SA
  • DTM06-12SB
  • Matching wedge lock (WM-12S)
  • Pins 0462-201-20141
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
Powering
Connect RaceCapture/Apex to a 12v source, ideally switched with main power or via ignition power.
Power requirements
Power requirements
Voltage 12-24v
Fused circuit 5A max
Analog Sensor inputs
Analog channel specifications
Voltage Range 0-5v
ADC precision 12 bit SAR
Connecting Sensors
You can connect RPM, wheel speed and other pulse-type sensors to RaceCapture/Apex frequency input pins.
Voltage Range 0-12v
Signal input quality
Special note about RPM inputs
Connecting Sensors
GPIO
RaceCapture/Apex provides 3 General Purpose Input Output (GPIO) ports which you can use to control devices (Output mode) or read switches or high / low states of electrical signals.
GPIO channel specifications
Input Mode
When configured for input mode, the RaceCapture/Apex sensor input will register a '1' when the input passes a voltage threshold of approximately 3v, and '0' when the input is low (close to 0 volts).
Important Note: when sensing large inductive loads, such as sensing brake light state or sensing the on/off state of a motor, connect a 10K 1/4 watt resistor in-line with the GPIO input to protect RaceCapture/Apex from a large inductive spike.
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
CAN channel specifications
CAN channels 2
CAN Filters 14 per channel
Auxiliary Serial
One Auxiliary RS232 compatible serial port is available on the main connector. You can use this to communicate with external devices that uses RS232 serial for communications.
