RaceCapture-Track MK3
Revision as of 01:00, 3 February 2023 by Brentp (talk | contribs)
Start it up
Plug it in
  • Plug one end of the OBDII cable into the RaceCapture Power/CAN port.
LED status
  • CAN - Shows activity on OBDII / CAN bus network, indicating data from your ECU and sensors is being received.
  • GPS - Shows GPS activity. Slow flash indicates acquiring a lock; rapid flash indicates GPS is locked.
  • Error - Indicates an error condition with the unit - see the RaceCapture app status page for details. It can also indicate an error with your Lua script (an optional feature of the system)
  • Power - Illuminates when the unit has power via 12v or USB.
  • Very fast green flash: Very rapid green flash indicates the unit is in bootloader mode, during firmware updates. If you see this when the the unit powers up and you cannot connect with the RaceCapture app, it usually means a failed firmware upgrade. You can resolve the issue by going through the firmware update process again.
Mounting
Place the RaceCapture system on a level surface in your car, with connectors facing the front of the vehicle. This is the factory orientation for the accelerometers and gyro.
Attach GNSS antenna
Attach the GNSS (AKA GPS) antenna connector to RaceCapture and screw to 5-6 inch lbs - just beyond finger tight to prevent the connector from vibrating loose. Do not overtighten.
Locating Antenna
  • Ideal: Mount the antenna on the roof of the vehicle, using the magnetic mount. Place the antenna with minimum 3 feet spacing from other transmitting antennas (car radios, cellular antennas, etc).
  • Alternate Mounting: You can mount it on the dashboard in clear view of the sky, or on the rear parcel tray under the back window. Note, this may degrade your GPS performance vs. roof mounting.
Download the app
  • Windows 10 and OSX: No USB drivers are needed for OSX or Windows 10.
  • Windows XP, 7, 8: Not supported due to outdated video drivers, but may work depending on the video hardware used. USB drivers will require installation instructions below.
First Time Setup
Connect the RaceCapture device to your computer via the supplied USB cable; this will also provide power to the unit. This is a good way to set up and test your RaceCapture system on the bench.
Android
We recommend connecting with Bluetooth when using Android devices.
Connecting with Bluetooth
  • Ensure RaceCapture is powered.
    • Note: The default password is 1234 - you can change this later under Setup.
Connecting with WiFi
  • Under Android settings, navigate to the WiFi section.
  • Wait until you see the RaceCapture WiFi network.
  • Select this network to connect.
    • Note: No password is required for the initial connection - you can set a password for your WiFi network later under Setup.
iOS
  • Under your iOS settings, navigate to the WiFi section.
Using the RaceCapture app
Extended Setup Guide
Alternative ways to power
USB
  • Note: OBDII is enabled by default on CAN1; CAN2 is recommended for secondary sensor networks.
Analog Inputs
Channels Battery Voltage (Internally connected) (0-20v)
CAN Bus
CAN Channels 2
CAN filters 14 per channel
CAN termination Internal jumper controlled; termination disabled by default
CAN channels supported 100
Cellular Telemetry
Via RaceCapture App 3G/4G depending on mobile device's capability (phone) or connected tablet + hotspot
GPS/GNSS
GNSS (GPS) Engine 1/5/10/25Hz native
Supported Constellations GPS, GLONASS, Beidou, Galileo
GNSS Antenna Triple band External / Magnetic roof mount
Wireless (WiFI)
WiFi 802.11bgn
Maximum Sample Rate (dashboard link) 50Hz
Wireless (Bluetooth)
Bluetooth (high speed) 2.0/2.1 EDR
General Features
Maximum Sample Rate 50Hz
Track Mapping Circuit and point-point
Track maps Unlimited - update from cloud
Sectors per track 20
Analysis
Included in the RaceCapture App + podium.live
Export data format Plain CSV (RaceRender and Dashware compatible)
Scripting / Customization
Real-time virtual (math) channels / custom channel mapping Via on-board Lua scripting
Virtual Channels 100
Physical
Dimensions 85 x 90 x 35mm (3.34 x 3.54 x 1.37in)
Temperature range -40 to 85c
Environmental IP50 rated
Weight 150g (5 oz)
Physical M8 4P connector for Power and CAN1 to ECU; M8 6P connection for CAN1 / CAN2 expansion to sensor networks
Power Consumption (max) 1.6W
