PodiumConnect Micro
Quick Start Guide
Connecting the Hardware
Mounting
Pigtail Connection
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
Create Your Podium Account
- Create an account on Podium
- Setup the Device Name
Windows/OSX
- Get the latest version of the RaceCapture app from the DOWNLOADS PAGE.
- If you are running Windows older than Windows 10, please install the USB driver, available from the SOFTWARE DOWNLOADS PAGE
- Start the RaceCapture app.
Android/iOS
First-Time Setup Wizard
Configure System Presets
Select Favorite Race Tracks
- Then, enter your WiFi SSID and Password to connect the device to your wireless network for telemetry streaming
Verify Telemetry
Verifying Wi-Fi
- Verify Client is connected
Verify Telemetry on Podium
Comprehensive Setup Guide
Data System Cable Connection
AIM Standard Cable
At a minimum, PodiumConnect requires the following data channels from your data system: Speed: Configured with 2 digits of precision in the CAN mapping (e.g. 33.24 kph) Latitude: Configured as decimal degrees of Latitude, with 6 digits of precision in the CAN mapping Longitude: Configured as decimal degrees of Longitude, with 6 digits of precision in the CAN mapping
CAN Bus Configuration
Baud Rate, Termination
CAN Channel Mapping Guide
Note : Full Channel Mapping Setup Guide
- A compatible Bluetooth device worn by the driver transmits both Driver ID and heart rate data to the PodiumConnect Micro.
- To enable automatic driver identification and heart rate data logging, you must manually add the channel by navigating to:
- Setup > CAN Mapping > Preset > Import
Telemetry and Logging Setup
Enabling WiFi Telemetry
Setting Sample Rates
Required Further Information
SD Card Logging
Buffering Telemetry to SD
Real-Time Podium Features
Live Data Streaming
Predictive Lap Timing
- RaceCapture offers a Predictive Lap Timing feature, which estimates your current lap time before it’s completed.
Driver Coaching Tools
Need more information
Monitoring Engine Vitals
Endurance Strategy Tools
Firmware and Software Updates
Backing Up Configurations
Updating Firmware
- Press Open
Restoring Settings
- AIM SMARTY CAM
- MOTEC
- RACELOGIC VBOX
- AEM CD-7 WITH VDM
- RACE TECHNOLOGY
- GENERIC CABLE INTEGRATION
