PodiumConnect Micro
Quick Start Guide
Connecting the Hardware
Mounting
Pigtail Connection
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
Create Your Podium Account
- Create an account on Podium
- Setup the Device Name
Windows/OSX
- Get the latest version of the RaceCapture app from the DOWNLOADS PAGE.
- If you are running Windows older than Windows 10, please install the USB driver, available from the SOFTWARE DOWNLOADS PAGE
- Start the RaceCapture app.
Android/iOS
First-Time Setup Wizard
Configure System Presets
Select Favorite Race Tracks
- Then, enter your WiFi SSID and Password to connect the device to your wireless network for telemetry streaming
Verify Telemetry
Verifying Wi-Fi
- Verify Client is connected
Verify Telemetry on Podium
Comprehensive Setup Guide
Data System Cable Connection
AIM Standard Cable
At a minimum, PodiumConnect requires the following data channels from your data system: Speed: Configured with 2 digits of precision in the CAN mapping (e.g. 33.24 kph) Latitude: Configured as decimal degrees of Latitude, with 6 digits of precision in the CAN mapping Longitude: Configured as decimal degrees of Longitude, with 6 digits of precision in the CAN mapping
CAN Bus Configuration
Baud Rate, Termination
CAN Channel Mapping Guide
Note : Full Channel Mapping Setup Guide
- A compatible Bluetooth device worn by the driver transmits both Driver ID and heart rate data to the PodiumConnect Micro.
- To enable automatic driver identification and heart rate data logging, you must manually add the channel by navigating to:
- Setup > CAN Mapping > Preset > Import
Telemetry and Logging Setup
Enabling WiFi Telemetry
Setting Sample Rates
Required Further Information
SD Card Logging
Buffering Telemetry to SD
Real-Time Podium Features
Live Data Streaming
Predictive Lap Timing
- RaceCapture offers a Predictive Lap Timing feature, which estimates your current lap time before it’s completed.
Driver Coaching Tools
Need more information
Monitoring Engine Vitals
Endurance Strategy Tools
Firmware and Software Updates
Backing Up Configurations
Updating Firmware
- Press Open
Restoring Settings
LED and Status Indicators
Required more information
Common Connectivity Issues
WiFi Stuck in “Checking WiFi Status” Loop
If the RaceCapture log repeatedly displays the following messages:
Checking WiFi Device... [CAN device] timeout rx CAN msg [esp8266] OP mode: 0 [ESP8266 Driver] Checking WiFi Device...
and WiFi connectivity is not working, perform a low-level factory reset of the WiFi module as follows:
- Back up your configuration
- Completely disable WiFi under Setup / Wireless
- Load the script below into the scripting window, ensuring you remove any existing script.
- Write the script
- Power cycle
- Check the log for no more repeated "Checking WiFi Device"..
- Perform a regular factory reset.
- Check for proper WiFi functionality (check if it shows up as an Access Point).
