| Input / Output Channels
| Analog Inputs
| Channels
8 (battery voltage dedicated on channel 8)
| Voltage range
0-5v
| Input impedance
1M ohm
| Voltage protection
400v (intermittent)
| ADC precision
12 bit
| Maximum sample rate
1000Hz
| Mapping
Raw / Linear formula / Interpolated map
| Digital I/O
| Channels
3
| Output mode type
Open drain
| Output current capacity
1A, inductive clamped
| Input mode voltage range
0-12v
| Input voltage protection
400v (intermittent)
| Maximum sample rate
1000Hz
| Timer Inputs (RPM / Frequency)
| Channels
3
400v (intermittent)
| Maximum sample rate
1000Hz
| PWM/Analog outputs
| PWM output type
push/pull
| PWM output voltage range
5v
50mA
| Analog Output
0-5v
| Voltage Reference
Output Voltage/Capacity: 5v / 1A
| Connectivity
| CAN Bus
| CAN Channels
2
| CAN baud rate
125K, 250K, 500K, 1M baud
| CAN filters
14 per channel
| Protocol support
OBDII PID, custom CAN messaging
| Telemetry/Wireless
| Cellular
Quad-band GSM (internal module, optional)
| Bluetooth
Bluetooth 2.0 (external module, optional)
| Serial
Type External RJ11
| Max Baud Rate
230400
| Inertial Motion Unit
| Accelerometer Channels
3 (X/Y/Z) (2G, 4G capable)
| Gyro
3 (Yaw/Pitch/Roll) (1000 degrees/sec)
| Magnetic compass
1 (Bearing) (device capable of 3)
| GPS
| GPS Type
External active antenna
| GPS Maximum sample rate
50Hz
| GPS accuracy
2.5M CEP
| Configuration Capacity
| Auto-detect track database
240
| Sectors per track
20
| Channel support
200
| Physical
| Dimensions
5.3″ (w) x 4.2″ (h) x 1.2″ (tall) / 135x110x31 mm(est)
| Weight
9oz / 255gm (est)
