Input / Output Channels
Analog Inputs
Channels
8 (battery voltage dedicated on channel 8)
Voltage range
0-5v
Input impedance
1M ohm
Voltage protection
400v (intermittent)
ADC precision
12 bit
Maximum sample rate
1000Hz
Mapping
Raw / Linear formula / Interpolated map
Digital I/O
Channels
3
Output mode type
Open drain
Output current capacity
1A, inductive clamped
Input mode voltage range
0-12v
Input voltage protection
400v (intermittent)
Maximum sample rate
1000Hz
Channels
3
400v (intermittent)
Maximum sample rate
1000Hz
PWM/Analog outputs
PWM output type
push/pull
PWM output voltage range
5v
50mA
Analog Output
0-5v
Voltage Reference
Output Voltage/Capacity: 5v / 1A
Connectivity
CAN Bus
CAN Channels
2
CAN baud rate
125K, 250K, 500K, 1M baud
CAN filters
14 per channel
Protocol support
OBDII PID, custom CAN messaging
Telemetry/Wireless
Cellular
Quad-band GSM (internal module, optional)
Bluetooth
Bluetooth 2.0 (external module, optional)
Serial
Type External RJ11
Max Baud Rate
230400
Inertial Motion Unit
Accelerometer Channels
3 (X/Y/Z) (2G, 4G capable)
Gyro
3 (Yaw/Pitch/Roll) (1000 degrees/sec)
Magnetic compass
1 (Bearing) (device capable of 3)
GPS Type
External active antenna
GPS Maximum sample rate
50Hz
GPS accuracy
2.5M CEP
Configuration Capacity
Auto-detect track database
240
Sectors per track
20
Channel support
200
Physical
Dimensions
5.3″ (w) x 4.2″ (h) x 1.2″ (tall) / 135x110x31 mm(est)
Weight
9oz / 255gm (est)
