RaceCapture-Pro MK3
Product Brief
- Jump to Quick Start
- Real-time Telemetry guide
- RaceCapture App user's guide
- Sensor guide
- Lua scripting guide
- How to: get best GPS data
- More FAQs and How-To's
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the app
- Google Play
- Amazon App Store
- iTunes - Search for 'RaceCapture'
Bluetooth (Android Only)
WiFi (iOS or Android)
USB Drivers
- Windows 10 and OSX: You're good to go: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
Once installed, plug RaceCapture/Pro into your computer via USB, then launch the RaceCapture software.
RaceCapture App Tour
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Selecting time vs distance
Applying Decals
