RaceCapture-Pro MK3
Revision as of 02:07, 25 March 2017 by Brentp (talk | contribs) (→Guides)
Product Brief
Download
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the app
Bluetooth (Android Only)
WiFi (iOS or Android)
USB Drivers
  • Windows 10 and OSX: You're good to go: No drivers are needed for OSX or Windows 10.
Once installed, plug RaceCapture/Pro into your computer via USB, then launch the RaceCapture software.
RaceCapture App Tour
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Navigating data
Selecting time vs distance
Applying Decals
