RaceCapture-Pro MK1
Revision as of 19:45, 25 March 2017 by Brentp (talk | contribs) (Brentp moved page RaceCapturePro MK2 to RaceCapture/Pro MK1)
Race Capture Pro MK2 Quick Links
Autosport Labs is excited to announce our latest project: RaceCapture/Pro mk2 - a powerful, multi-channel data acquisition and control system for motorsport applications
Impact
Significance
While the primary application of RaceCapture/Pro mk2 is focused towards race car data acquisition, its powerful processor combined with a wealth of inputs and outputs also makes RaceCapture/Pro a general purpose automotive computer, one capable of handling many different tasks - limited only by your imagination. If the question is "Can RaceCapture do ...?" the answer will likely be 'Yes' and often with little to no external hardware support necessary.
Flexibility
On-board scripting
Some Examples:
Software Connectivity
RaceCapture/Pro features software to:
  • Customize logging channels
  • View Runtime Data
  • Edit custom scripting
Infinite Possibilities
  • Source code
Technical Specifications
Input and Output Channels
RaceCapture mk2 offers 21 input and output channels and serial communication port, enough to handle complex logging and control tasks.
  • 50Hz GPS module
    • Internal state of the art GPS module
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time. Real time predictive timing.
  • Auxiliary Serial Port
  • CAN Bus Expansion
    • Two high speed CAN bus ports provide the ability to virtually interface with any type of CAN bus enabled equipment, from ECUs to tire temperature sensors.
Logging
CPU
  • 168MHz 32 bit ARM processor
Input/Output Protection
  • 40v protection on all input pins
Mechanical
  • Compact, rugged design
    • Weighs 8.4oz
    • Real-Time module weighs 7oz
  • On-board Status LEDs
Power
      • TODO ***
  • 9-17v power
  • < 100mA for RaceCapture/Pro.
  • May burst to 2A temporarily when using RealTime Telemetry module
Example Sensor Connectivity
