RaceCapture-Pro MK2
Revision as of 00:32, 14 October 2014 by Jstoezel (talk | contribs) (moved RaceCapturePro to RaceCapturePro MK1: Integrating MK2)
Race Capture Pro Quick Links
10Hz GPS
Rev F board
Connectors View
Terminal Block
Impact
Significance
Flexibility
On-board scripting
Some Examples:
Software Connectivity
  • Customize logging channels
  • View Runtime Data
  • Edit custom scripting
Infinite Possibilities
  • Source code
Technical Specifications
Input and Output Channels
  • 10Hz GPS module input
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
  • Auxiliary Serial Port
  • Digital expansion port
    • A high speed port provides the ability to add CAN bus expansion, more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
CPU
  • 48MHz 32 bit ARM processor
Input/Output Protection
  • 40v protection on all input pins
Mechanical
  • Compact, rugged design
    • Weighs 8.4oz
    • Real-Time module weighs 7oz
  • On-board Status LEDs
Power
  • 9-17v power
  • < 100mA for RaceCapture/Pro.
  • May burst to 2A temporarily when using RealTime Telemetry module
Example Sensor Connectivity
