RaceCapture-Pro MK2
Revision as of 07:21, 14 December 2014 by Brentp (talk | contribs) (→Getting Started: removed inoperative links)
RaceCapture/Pro Quick Links
Getting Started
Previous Hardware Versions
RaceCapture/Pro MK1
Input / Output Channels
Analog Inputs
Voltage range 0-5v
Input impedance 1M ohm
ADC precision 12 bit
Maximum sample rate 1000Hz
Digital I/O
Channels 3
Output mode type Open drain
Channels 3
PWM/Analog outputs
PWM output type push/pull
PWM output voltage range 5v
Output current capacity 50mA
Analog Output 0-5v
Voltage Reference Output Voltage/Capacity: 5v / 1A
Connectivity
CAN Bus
CAN Channels 2
CAN filters 14 per channel
Telemetry/Wireless
Cellular Quad-band GSM (internal module, optional)
Serial Type External RJ11
Max Baud Rate 230400
Inertial Motion Unit
Magnetic compass 1 (Bearing) (device capable of 3)
GPS Maximum sample rate 50Hz
GPS accuracy 2.5M CEP
Configuration Capacity
Sectors per track 20
Channel support 200
Physical
Dimensions 5.3″ (w) x 4.2″ (h) x 1.2″ (tall) / 135x110x31 mm(est)
Weight 9oz / 255gm (est)
