RaceCapture-Track MK2
Revision as of 20:31, 11 September 2019 by Sbarton (talk | contribs) (How To)
Start it up
Plug it in
  • Plug one end of the OBDII cable into the RaceCapture RJ45 port.
Mounting
Place the RaceCapture system on a level surface in your car, with the connectors facing forward and logo up. This is the factory orientation for the accelerometers and gyro.
Attach GPS
Locating Antenna
  • Ideal: Mount the antenna on the roof of the vehicle, using the magnetic mount. Place the antenna with minimum 3 feet spacing from other transmitting antennas (car radios, cellular antennas, etc).
  • Alternate Mounting: You can mount it on the dashboard in clear view of the sky, or on the rear parcel tray under the back window. Note, this may degrade your GPS performance vs. roof mounting.
Download the app
First Time Setup
Android
We recommend connecting with Bluetooth when using Android devices.
Connecting with Bluetooth
  • Ensure RaceCapture is powered.
    • Note: The default password is 1234 - you can change this later under Setup.
Connecting with WiFi
  • Under Android settings, navigate to the WiFi section.
  • Wait until you see the RaceCapture WiFi network.
  • Select this network to connect.
    • Note: No password is required for the initial connection - you can set a password for your WiFi network later under Setup.
iOS
  • Under your iOS settings, navigate to the WiFi section.
Launching the first time Setup
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Notes about Android devices
Analysis
Navigating data
Selecting time vs distance
RaceRender
Applying Decals
Extended Setup Guide
Alternative ways to power
USB
Custom Cable
You can build a custom cable for power and CAN bus using a standard CAT-5 ethernet cable with an RJ45 connector. Wire up using the following diagram.
  • Note: OBDII is enabled by default on CAN1; CAN2 is recommended for secondary sensor networks.
Connection RaceCapture/Track MK2 (RJ45 cable)
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Integrating AnalogX
Suggested parts
  • RJ45 Splitter "Hub" shaped
Splice the following connections between AnalogX and an RJ45 cable with one end cut, forming a pigtail.
AnalogX will receive power from the OBDII cable, and provide data to RaceCapture via CAN2.
Wiring AnalogX to RaceCapture/Track MK2 CAN2 EIA-T568B RJ45 cable color codes (check printing on the cable to confirm)
Connection AnalogX connection RaceCapture/Pro or RaceCapture/Track MK2 (RJ45 cable)
+12v Red Brown
Ground Blue Orange/White
CAN 2 High Black Blue
CAN 2 Low Orange Blue/White
Enabling the CAN preset and calibrating sensors
Setting CAN baud rate
The default baud rate for AnalogX is 500K. If you still have it set to the default, ensure this is set under the CAN bus settings.
Selecting the AnalogX preset
Steps to recover:
  • Connect RaceCapture via USB
Analog Inputs
Channels Battery Voltage (Internally connected) (0-20v)
CAN Bus
CAN Channels 2
CAN filters 14 per channel
CAN termination Internal jumper controlled; termination disabled by default
CAN channels supported 100
Cellular Telemetry
Via RaceCapture App 3G/4G depending on mobile device's capability (phone) or connected tablet + hotspot
GPS Engine 1/5/10/25/50Hz native
GPS Antenna External / Magnetic roof mount
Wireless (WiFI)
WiFi 802.11bgn
Maximum Sample Rate (dashboard link) 50Hz
Wireless (Bluetooth)
Bluetooth (high speed) 2.0/2.1 EDR
General Features
Maximum Sample Rate 50Hz
Track Mapping Circuit and point-point
Track maps Unlimited - update from cloud
Sectors per track 20
Analysis
Included in the RaceCapture App + podium.live
Export data format Plain CSV (RaceRender and Dashware compatible)
Scripting / Customization
Real-time virtual (math) channels / custom channel mapping Via on-board Lua scripting
Virtual Channels 100
Physical
Dimensions 76.2 x 50 x 22mm (3 x 2 x 0.85in)
Temperature range -40 to 85c
Environmental IP50 rated
Weight 170g (6 oz)
Physical RJ45 Connector, 8 pins provides power + OBDII / CAN connectivity SMA for external GPS antenna
Power Consumption (max) 1.6W
