RaceCapture-Pro MK3
- How to: get best GPS data
- How to: analyze your data
- More FAQs and How-To's
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
- Note: When powering only with USB, the voltage reference output will only be at approximately 4.7 volts, which can cause a mis-reading of sensor values. When precise sensor readings are required, provide power directly via the terminal block.
Launch the app
- Google Play
- Amazon App Store
- iTunes - Search for 'RaceCapture'
Bluetooth (Android Only)
WiFi (iOS or Android)
USB Drivers
- Windows 10 and OSX: You're good to go: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
Once installed, plug RaceCapture/Pro into your computer via USB, then launch the RaceCapture software.
RaceCapture App Tour
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Selecting time vs distance
Applying Decals
Recommended Tablets
Primary recommendation
- Nvidia Shield Tablet: $199.99 from Nvidia directly. Also available on Amazon and other retailers
Lower end recommendation
- Amazon Fire tablet: $49.95 edition
