RaceCapture-Track MK2
Start it up
Plug it in
- Plug one end of the OBDII cable into the RaceCapture RJ45 port.
LED status
- * Very fast green flash': Very rapid green flash indicates the unit is in bootloader mode, during firmware updates. If you see this when the the unit powers up and you cannot connect with the RaceCapture app, it usually means a failed firmware upgrade. You can resolve the issue by going through the firmware update process again.
- Blue : WiFi activity
- Red: Firmware error
Mounting
Place the RaceCapture system on a level surface in your car, with the connectors facing forward and logo up. This is the factory orientation for the accelerometers and gyro.
Attach GPS
Locating Antenna
- Ideal: Mount the antenna on the roof of the vehicle, using the magnetic mount. Place the antenna with minimum 3 feet spacing from other transmitting antennas (car radios, cellular antennas, etc).
- Alternate Mounting: You can mount it on the dashboard in clear view of the sky, or on the rear parcel tray under the back window. Note, this may degrade your GPS performance vs. roof mounting.
Download the app
- Windows 10 and OSX: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
First Time Setup
Android
We recommend connecting with Bluetooth when using Android devices.
Connecting with Bluetooth
- Ensure RaceCapture is powered.
- Note: The default password is 1234 - you can change this later under Setup.
Connecting with WiFi
- Under Android settings, navigate to the WiFi section.
- Wait until you see the RaceCapture WiFi network.
- Select this network to connect.
- Note: No password is required for the initial connection - you can set a password for your WiFi network later under Setup.
iOS
- Under your iOS settings, navigate to the WiFi section.
Launching the first time Setup
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Notes about Android devices
Analysis
Selecting time vs distance
RaceRender
Applying Decals
Extended Setup Guide
Alternative ways to power
USB
Custom Cable
You can build a custom cable for power and CAN bus using a standard CAT-5 ethernet cable with an RJ45 connector. Wire up using the following diagram.
- Note: OBDII is enabled by default on CAN1; CAN2 is recommended for secondary sensor networks.
| Connection | RaceCapture/Track MK2 (RJ45 cable) |
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
| CAN 2 High | Blue |
| CAN 2 Low | Blue/White |
Integrating AnalogX
Suggested parts
- RJ45 Splitter "Hub" shaped
Splice the following connections between AnalogX and an RJ45 cable with one end cut, forming a pigtail.
AnalogX will receive power from the OBDII cable, and provide data to RaceCapture via CAN2.
| Connection | AnalogX connection | RaceCapture/Pro or RaceCapture/Track MK2 (RJ45 cable) |
| +12v | Red | Brown |
| Ground | Blue | Orange/White |
| CAN 2 High | Black | Blue |
| CAN 2 Low | Orange | Blue/White |
Enabling the CAN preset and calibrating sensors
Setting CAN baud rate
The default baud rate for AnalogX is 500K. If you still have it set to the default, ensure this is set under the CAN bus settings.
Selecting the AnalogX preset
Steps to recover:
- Connect RaceCapture via USB
- How to: get best GPS data
- How to update firmware
- Add TPMS Data
- More FAQs and How-To's
- How To Videos
| Analog Inputs | |
| Channels | Battery Voltage (Internally connected) (0-20v) |
| CAN Bus | |
| CAN Channels | 2 |
| CAN termination | Internal jumper controlled; termination disabled by default |
| CAN channels supported | 100 |
| Cellular Telemetry | |
| Via RaceCapture App | 3G/4G depending on mobile device's capability (phone) or connected tablet + hotspot |
| GPS | |
| GPS Engine | 1/5/10/25/50Hz native |
| GPS Antenna | External / Magnetic roof mount |
| Wireless (WiFI) | |
| WiFi | 802.11bgn |
| Maximum Sample Rate (dashboard link) | 50Hz |
| Wireless (Bluetooth) | |
| Bluetooth (high speed) | 2.0/2.1 EDR |
| General Features | |
| Maximum Sample Rate | 50Hz |
| Track Mapping | Circuit and point-point |
| Track maps | Unlimited - update from cloud |
| Sectors per track | 20 |
| Analysis |
Included in the RaceCapture App + podium.live |
| Export data format | Plain CSV (RaceRender and Dashware compatible) |
| Real-time virtual (math) channels / custom channel mapping | Via on-board Lua scripting |
| Virtual Channels | 100 |
| Physical | |
| Dimensions | 76.2 x 50 x 22mm (3 x 2 x 0.85in) |
| Weight | 170g (6 oz) |
| Physical | RJ45 Connector, 8 pins provides power + OBDII / CAN connectivity SMA for external GPS antenna |
| Power Consumption (max) | 1.6W |
