RaceCapture-Pro MK2
Revision as of 19:01, 23 December 2014 by Brentp (talk | contribs) (→Getting Started)
RaceCapture/Pro Quick Links
Getting Started
Previous Hardware Versions
RaceCapture/Pro MK1
Quick Reference
Download a printable PDF
Input / Output Channels
Analog Inputs
Voltage range 0-5v
Input impedance 1M ohm
ADC precision 12 bit
Maximum sample rate 1000Hz
Digital I/O
Channels 3
Output mode type Open drain
Channels 3
PWM/Analog outputs
PWM output type push/pull
PWM output voltage range 5v
Output current capacity 50mA
Analog Output 0-5v
Voltage Reference
Connectivity
CAN Bus
CAN Channels 2
CAN filters 14 per channel
Telemetry/Wireless
Cellular Quad-band GSM (internal module, optional)
Serial Type External RJ11
Max Baud Rate 230400
Inertial Motion Unit
Magnetic compass 1 (Bearing) (device capable of 3)
GPS Maximum sample rate 50Hz
GPS accuracy 2.5M CEP
Storage
Micro SD Up to 32GB (SDHC)
Configuration Capacity
Sectors per track 20
Channel support 200
Physical
Dimensions 5.3″ (w) x 4.2″ (h) x 1.2″ (tall) / 135x110x31 mm(est)
Weight 9oz / 255gm (est)
