RaceCapture-Pro MK2
RaceCapture/Pro Quick Links
Getting Started
How To's
- How to: Connect RPM
- How to: set up telemetry
- How to: get best GPS data
- How to: Integrate CAN bus data
- More FAQs and How-To's
User Guides
More Information
Previous Hardware Versions
Quick Reference
Download a printable PDF
| Input / Output Channels | |
| Analog Inputs | |
| Voltage range | 0-5v |
| Input impedance | 1M ohm |
| ADC precision | 12 bit |
| Digital I/O | |
| Channels | 3 |
| Channels | 3 |
| PWM/Analog outputs | |
| Channels | 4 |
| Analog Output | 0-5v |
| Voltage Reference | |
| Connectivity | |
| CAN Bus | |
| CAN Channels | 2 |
| Protocol support | OBDII PID, custom CAN messaging |
| Telemetry/Wireless | |
| Cellular | Quad-band GSM (internal module, optional) |
| Serial | Type External RJ11 |
| Max Baud Rate | 230400 |
| Inertial Motion Unit | |
| Magnetic compass | 1 (Bearing) (device capable of 3) |
| GPS | |
| GPS accuracy | 2.5M CEP |
| Storage | |
| Configuration Capacity | |
| Sectors per track | 20 |
| Channel support | 200 |
| Physical | |
| Dimensions | 5.3″ (w) x 4.2″ (h) x 1.2″ (tall) / 135x110x31 mm(est) |
| Temperature | Max Internal Temperature while operating: -40°C ~ 85°C / -40°C ~ 80°C (Telemetry module) |
