RaceCapture-Pro MK2
RaceCapture/Pro Quick Links
Getting Started
- How to: set up telemetry
- RaceCapture App User's Guide
- Sensor Guide
- Lua Scripting Guide
- Source code
- CAN Integration support
Previous Hardware Versions
Quick Reference
Download a printable PDF
Input / Output Channels | |
Analog Inputs | |
Channels | 8 (battery voltage dedicated on channel 8) |
Voltage range | 0-5v |
Input impedance | 1M ohm |
Voltage protection | 400v (intermittent) |
ADC precision | 12 bit |
Maximum sample rate | 1000Hz |
Mapping | Raw / Linear formula / Interpolated map |
Digital I/O | |
Channels | 3 |
Output mode type | Open drain |
Output current capacity | 1A, inductive clamped |
Input voltage protection | 400v (intermittent) |
Timer Inputs (RPM / Frequency) | |
Channels | 3 |
PWM/Analog outputs | |
PWM output type | push/pull |
PWM output voltage range | 5v |
Output current capacity | 50mA |
Analog Output | 0-5v |
Voltage Reference | |
Output Voltage/Capacity | 5v / 1A |
Connectivity | |
CAN Bus | |
CAN Channels | 2 |
CAN baud rate | 125K, 250K, 500K, 1M baud |
Protocol support | OBDII PID, custom CAN messaging |
Telemetry/Wireless | |
Cellular | Quad-band GSM (internal module, optional) |
Bluetooth | Bluetooth 2.0 (external module, optional) |
Serial | Type External RJ11 |
Max Baud Rate | 230400 |
Inertial Motion Unit | |
Accelerometer Channels | 3 (X/Y/Z) (2G, 4G capable) |
Gyro | 3 (Yaw/Pitch/Roll) (1000 degrees/sec) |
Magnetic compass | 1 (Bearing) (device capable of 3) |
GPS | |
GPS Type | External active antenna |
GPS Maximum sample rate | 50Hz |
GPS accuracy | 2.5M CEP |
Storage | |
Configuration Capacity | |
Auto-detect track database | 240 |
Sectors per track | 20 |
Channel support | 200 |
Physical | |
Dimensions | 5.3″ (w) x 4.2″ (h) x 1.2″ (tall) / 135x110x31 mm(est) |
Weight | 9oz / 255gm (est) |
Temperature | Max Internal Temperature while operating: -40°C ~ 85°C / -40°C ~ 80°C (Telemetry module) |
