PodiumConnect
Revision as of 20:57, 3 March 2018 by Brentp (talk | contribs)
Getting Started
Installing the app
Android / iOS
Running and Connection
  • Start the RaceCapture app.
Android / iOS
    • Note, the WiFi Access Point is open, with no password - you can set a password and encryption later under Setup.
First time setup wizard
  • Select your device and verify the RaceCapture app connects.
  • Select the preset configuration matching the data system you have.
Select your favorite Tracks
Create an account on Podium / Setting Device ID
  • Create an account on Podium http://podium.live - then follow the steps to create a Device. Make a note of the Device ID provided, so you can enter it into the wizard.
Select your cell provider
  • Enable the cellular connection and select your cellular provider.
    • Note: If your cellular provider is not in the list, select the custom option and set the APN settings provided by your cellular carrier.
Freedom Pop
Further Setup
  • Note To re-run the first time setup, launch the RaceCapture app without a connection to the device, go to the setup screen and press the First Time Setup button.
Connecting your Data System
  • Speed
  • GPS data
    • Latitude
    • Longitude
These channels allow PodiumConnect to calculate lap timing, which creates the context for analysing additional sensor data, such as temperatures, TPS, RPM, oil pressure and so on. Without these channels, telemetry will not work properly.
Testing Telemetry
Install your SIM card
  • Slide the SIM card tray back into the drawer, ensuring you engage the drawer slot carefully. Press gently until the drawer seats.
Verifying
  • Refresh this page when telemetry is broadcasting; you will see an Ad Hoc event listed.
Installing the unit
  • Note Mounting orientation does not matter.
Using Podium
Additional Guides and How-Tos
