PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
First time setup wizard
Select your favorite Tracks
Select your cell provider
Freedom Pop
Further Setup
Connecting your Data System
- Speed
- GPS data
- Latitude
- Longitude
- Important: Without these channels, telemetry will not work properly.
Testing Telemetry
Install your SIM card
Verifying
Installing the unit
Using Podium
Additional Guides and How-Tos
- Logging Data
- Lua scripting guide
- Lua script examples
- GoPro control guide
