RaceCapture-Apex
Product Brief
- Jump to quick start guide
- Hardware Installation guide
- Real-time Telemetry guide
- CAN bus / ECU sensor guide
- Lua scripting guide
- Sensor guide
- GoPro control guide
- How to: get best GPS data
- More FAQs and How-To's
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Connect 12-24v and Ground to the connections on the connector according to the pinout in the [[RacecaptureApex_hardware_install]|ardware installation guide]].
Testing on the Bench
Launch the app
Bluetooth (Android Only)
WiFi (iOS or Android)
Windows Requirements
USB Drivers
- Windows XP, 7 or 8
OSX
Connecting and running
RaceCapture App Tour
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Selecting time vs distance
