PodiumConnect
Revision as of 17:47, 29 March 2019 by Sbarton (talk | contribs) (→Guides)
Getting Started
Installing the app
Android / iOS
Running and Connection
    • If you are running Windows older than Windows 10, please install the USB driver, available from the Software Downloads page
  • Start the RaceCapture app.
Android / iOS
    • Note, the WiFi Access Point is open, with no password - you can set a password and encryption later under Setup.
First time setup wizard
  • Select your device and verify the RaceCapture app connects.
  • Select the preset configuration matching the data system you have.
Select your favorite Tracks
  • Create an account on Podium http://podium.live - then follow the steps to create a Device. Make a note of the Device ID provided, so you can enter it into the wizard.
Select your cell provider
  • Enable the cellular connection and select your cellular provider.
    • Note: If your cellular provider is not in the list, select the custom option and set the APN settings provided by your cellular carrier.
Freedom Pop
Further Setup
  • Note To re-run the first time setup, launch the RaceCapture app without a connection to the device, go to the setup screen and press the First Time Setup button.
Connecting your Data System
  • Speed
  • GPS data
    • Latitude
    • Longitude
  • Important: Without these channels, telemetry will not work properly.
The main connector on PodiumConnect is a standard Molex MiniFit Jr connector.
  • Plug Housing: Molex Mini Fit Jr. (8 position) 0039012080
Testing Telemetry
Install your SIM card
  • Slide the SIM card tray back into the drawer, ensuring you engage the drawer slot carefully. Press gently until the drawer seats.
Verifying
  • Refresh this page when telemetry is broadcasting; you will see an Ad Hoc event listed.
Installing the unit
  • Note Mounting orientation does not matter.
Using Podium
Additional Guides and How-Tos
