RaceCapture-Pro MK2
Revision as of 18:44, 24 May 2016 by Brentp (talk | contribs) (→How To)
RaceCapture/Pro Quick Links
Getting Started
User Guides
By Car
By Sensor Type
Reference
More Information
Previous Hardware Versions
RaceCapture/Pro MK1
Quick Reference
Download a printable PDF
Input / Output Channels
Analog Inputs
Voltage range 0-5v
Input impedance 1M ohm
ADC precision 12 bit
Maximum sample rate 1000Hz
Digital I/O
Channels 3
Output mode type Open drain
Channels 3
PWM/Analog outputs
Channels 4
PWM output type push/pull
PWM output voltage range 5v
Output current capacity 50mA
Analog Output 0-5v
Voltage Reference
Connectivity
CAN Bus
CAN Channels 2
CAN filters 14 per channel
Telemetry/Wireless
Max Baud Rate 230400
Inertial Motion Unit
Magnetic compass 1 (Bearing) (device capable of 3) (*Coming in 2.9.x firmware)
GPS Maximum sample rate 50Hz
GPS accuracy 2.5M CEP
Storage
Micro SD Up to 32GB (SDHC)
Configuration Capacity
Sectors per track 20
Channel support 200
Physical
Weight 9oz / 255gm (est)
With Bluetooth: 1.6W
With Cellular Telemetry: 8.6W
