PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
First time setup wizard
Select your favorite Tracks
Then, enter this Device ID into the Setup Wizard.
Select your cell provider
Verizon
AT&T
Freedom Pop
Further Setup
Connecting your Data System
- Speed
- Latitude
- Configured with 6 digits of precision in the CAN mapping
- Longitude
This minimum data will allow PodiumConnect to calculate lap timing, which creates the context for analysing additional sensor data, such as temperatures, TPS, RPM, oil pressure and so on.
PodiumConnect MK2
AIM integration cable
If your system was provided with the AIM integration cable, connect it to AIM data hub.
Pigtail harness
- Connector: M8 4P, A coding
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
PodiumConnect MK1
The main connector on PodiumConnect MK1 is a standard Molex MiniFit Jr connector.
Testing Telemetry
Install your SIM card
Verifying
=Using an SD card for telemetry buffering
To enhance telemetry performance, you can optionally use an SD card to buffer data in cases where cellular connectivity temporarily drops while on the race track.
If this happens, PodiumConnect will save data to the SD card, and then will burst the data upon re-connection. The amount of buffering provided is limited to approximately one lap (3 minutes of data). Therefore, this buffering is optimized for race tracks with small to moderate interruption of cellular coverage.
Enabling SD card buffering
Installing the unit
Using Podium
Updating Firmware
Backup your configuration
Steps:
Update the PodiumConnect Firmware
- Press Open
Restore your settings
Recommended Cellular Services by country
- UK: Telefonica O2
- Italy: Vodafone Italy
Additional Guides and How-Tos
- Logging Data
- Real-time Telemetry guide
- Lua scripting guide
- Lua script examples
- GoPro control guide
- Add TPMS data for $225
- How to update firmware
- More FAQs and How-To's
- How To Videos
| Analog Inputs | |
| Channels | 1 (Battery Voltage, Internally connected (0-20v)) |
| CAN Bus | |
| CAN Channels | 2 |
| CAN channels supported | 100 |
| Serial | |
| Aux Serial | RS232 |
| Max Baud Rate | 230400 |
| Wireless | |
| WiFi | 802.11bgn |
| Maximum Sample Rate (dashboard link) | 50Hz |
| Storage | |
| Maximum Sample Rate | 100Hz |
| Track maps | 200 built in for autonomous auto-detection |
| Sectors per track | 20 |
| Analysis | Included in the RaceCapture App, and on Podium |
| Export data format | Plain CSV (RaceRender compatible) |
| Real-time virtual (math) channels / custom channel mapping | Via on-board Lua scripting |
| Virtual Channels | 100 |
| Physical | |
| Dimensions | 85 x 85 x 36mm (3.35 x 3.35 x 1.41in) |
| Temperature range | 0 to 65c |
| Weight | 170g (6 oz) |
| Physical | Molex Connector, 8 pins SMA for cellular module |
| Power Consumption (max) | Main System: 0.6W
With Wireless: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Wireless active: 9.6W |
