RaceCapture-Pro MK3
Revision as of 04:27, 11 November 2017 by Sbarton (talk | contribs) (Guides)
Product Brief
Download
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the app
Bluetooth (Android Only)
WiFi (iOS or Android)
Windows Requirements
USB Drivers
  • Windows XP, 7 or 8
OSX
Connecting and running
RaceCapture App Tour
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Navigating data
Selecting time vs distance
Applying Decals
