PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
- Start the RaceCapture app.
Android / iOS
First time setup wizard
Select your favorite Tracks
Select your cell provider
Verizon
If you have the newer 4G enabled system, you can also use a Verizon SIM card (USA). If your unit was bundled with a SIM card, you can call Wireless Zone at 508-834-3311 for activation and access to special data plan options.
AT&T
You can get an AT&T SIM card at your local AT&T store. Request a data sim suitable for a data only tablet.
Freedom Pop
Note about setting up FredomPop's $0/month service
Please note that FreedomPop is a 3rd party provider; For USA customers we are including a bundled SIM card as an optional convenience. These are the same SIM cards you can order from them separately.
If your goal is to use the $0/month plan that includes 200MB, follow these steps:
- Register the SIM card per their web site process
- Go into your account, then downgrade and remove services as needed to get down to the "basic" free plan. There will be a number of steps to follow, with warning messages.
- Be sure to remove any add on paid services.
- When done, your monthly bill should show $0.
Note, FreedomPop may require you to have a small balance in your account to cover instances if you go over the 200MB monthly allotment. If you don't go over this, then you should not have to pay an additional fee.
See here fore more detailed info on how to get free sim cards and free data from FreedomPop.
Any additional questions, please contact FreedomPop support.
Further Setup
Connecting your Data System
- Speed
- Latitude
- Longitude
The main connector on PodiumConnect is a standard Molex MiniFit Jr connector.
Testing Telemetry
Install your SIM card
Verifying
Installing the unit
Using Podium
Updating Firmware
Backup your configuration
Steps:
Update the PodiumConnect Firmware
- Press Open
Restore your settings
Additional Guides and How-Tos
- Logging Data
- Real-time Telemetry guide
- Lua scripting guide
- Lua script examples
- GoPro control guide
- Add TPMS data for $225
- How to update firmware
- More FAQs and How-To's
- How To Videos
| Analog Inputs | |
| Channels | 1 (Battery Voltage, Internally connected (0-20v)) |
| CAN Bus | |
| CAN Channels | 2 |
| CAN channels supported | 100 |
| Serial | |
| Aux Serial | RS232 |
| Max Baud Rate | 230400 |
| Wireless | |
| WiFi | 802.11bgn |
| Maximum Sample Rate (dashboard link) | 50Hz |
| Storage | |
| Maximum Sample Rate | 100Hz |
| Track maps | 200 built in for autonomous auto-detection |
| Sectors per track | 20 |
| Analysis | Included in the RaceCapture App, and on Podium |
| Export data format | Plain CSV (RaceRender compatible) |
| Real-time virtual (math) channels / custom channel mapping | Via on-board Lua scripting |
| Virtual Channels | 100 |
| Physical | |
| Dimensions | 85 x 85 x 36mm (3.35 x 3.35 x 1.41in) |
| Temperature range | 0 to 65c |
| Weight | 170g (6 oz) |
| Physical | Molex Connector, 8 pins SMA for cellular module |
| Power Consumption (max) | Main System: 0.6W
With Wireless: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Wireless active: 9.6W |
