PodiumConnect
Getting Started
Installing the app
Android / iOS
Running and Connection
    • If you are running Windows older than Windows 10, please install the USB driver, available from the Software Downloads page
  • Start the RaceCapture app.
Android / iOS
    • Note, the WiFi Access Point is open, with no password - you can set a password and encryption later under Setup.
First time setup wizard
  • Select your device and verify the RaceCapture app connects.
  • Select the preset configuration matching the data system you have.
Select your favorite Tracks
  • Create an account on Podium http://podium.live - then follow the steps to create a Device. Make a note of the Device ID provided, so you can enter it into the wizard.
Then, enter this Device ID into the Setup Wizard.
  • Note: You can set the Device ID later under Setup / Telemetry
Select your cell provider
  • Enable the cellular connection and select your cellular provider.
    • Note: If your cellular provider is not in the list, select the custom option and set the APN settings provided by your cellular carrier.
Verizon
  • If your unit was bundled with a SIM card, you can call Wireless Zone at 508-834-3311 for activation and access to special data plan options.
AT&T
Freedom Pop
Note about setting up FredomPop's $0/month service
Please note that FreedomPop is a 3rd party provider; For USA customers we are including a bundled SIM card as an optional convenience. These are the same SIM cards you can order from them separately.
If your goal is to use the $0/month plan that includes 200MB, follow these steps:
  • Register the SIM card per their web site process
  • Go into your account, then downgrade and remove services as needed to get down to the "basic" free plan. There will be a number of steps to follow, with warning messages.
  • Be sure to remove any add on paid services.
  • When done, your monthly bill should show $0.
Note, FreedomPop may require you to have a small balance in your account to cover instances if you go over the 200MB monthly allotment. If you don't go over this, then you should not have to pay an additional fee.
See here fore more detailed info on how to get free sim cards and free data from FreedomPop.
Any additional questions, please contact FreedomPop support.
Further Setup
  • Note To re-run the first time setup, launch the RaceCapture app without a connection to the device, go to the setup screen and press the First Time Setup button.
Connecting your Data System
  • Speed
  • Latitude
  • Longitude
  • Important: Without these channels, telemetry will not work properly. Please do not change the names of the default channels provided by the presets.
The main connector on PodiumConnect is a standard Molex MiniFit Jr connector.
  • Plug Housing: Molex Mini Fit Jr. (8 position) 0039012080
Testing Telemetry
Install your SIM card
  • Slide the SIM card tray back into the drawer, ensuring you engage the drawer slot carefully. Press gently until the drawer seats.
Verifying
  • Refresh this page when telemetry is broadcasting; you will see an Ad Hoc event listed.
Installing the unit
  • Note Mounting orientation does not matter.
Using Podium
Updating Firmware
Backup your configuration
Steps:
  • Connect to PodiumConnect using the RaceCapture app - using USB, or WiFi.
  • Navigate to Setup and press the Read button to read the current settings from PodiumConnect.
Update the PodiumConnect Firmware
  • Connect PodiumConnect via USB (Windows or OSX only)
  • Navigate to the PodiumConnect firmware you unzipped. The file will end with the extension '.ihex'. Example: PodiumConnect_2.15.2.ihex
  • Press Open
Restore your settings
Additional Guides and How-Tos
Analog Inputs
Channels 1 (Battery Voltage, Internally connected (0-20v))
CAN Bus
CAN Channels 2
CAN filters 14 per channel
CAN channels supported 100
Serial
Aux Serial RS232
Max Baud Rate 230400
Cellular Telemetry (Optional)
Cellular 3.5G GSM worldwide compatible
WiFi 802.11bgn
Maximum Sample Rate (dashboard link) 50Hz
Storage
Micro SD Up to 32GB (SDHC)
Maximum Sample Rate 100Hz
Track Mapping Circut and point-point
Track maps 200 built in for autonomous auto-detection
Sectors per track 20
Analysis Included in the RaceCapture App, and on Podium
Export data format Plain CSV (RaceRender compatible)
Scripting / Customization
Real-time virtual (math) channels / custom channel mapping Via on-board Lua scripting
Virtual Channels 100
Physical
Dimensions 85 x 85 x 36mm (3.35 x 3.35 x 1.41in)
Temperature range 0 to 65c
Environmental IP50 rated
Weight 170g (6 oz)
Physical Molex Connector, 8 pins SMA for cellular module
With Wireless: 1.6W With Cellular Telemetry: 8.6W
With Cellular Telemetry and Wireless active: 9.6W
